First let me mention, I know there has been tons of threads on this topic, and I've searched under this particular sub-forum, under my TV model and have read them all. So I apologize in advance if anyone feels this has been covered. My neighbor was throwing away his plasma and I felt compelled to save it from the dump. I'll also mention the panel itself looks to me, to be in perfect condition. I've done days of research on this and followed the flow chart on the diagnostic manual and it told me to replace the SC board to remedy my 10 blink code. My old one was dead in the water, no green LED or anything. Power supply seems okay to me and fans spin up until the TV clicks off. Ordered a refurbished replacement SC board that arrived today so I installed it. I probably made a mistake not disconnecting anything downstream of the SC board (buffer boards and panel) but now its a little too late for that. So my blinking changed from 10 to 7 and the green LED IS working on the new SC board. I've tried isolating the buffer boards to see if I can get any change in the blinking and it remains 7 no matter what. I'm prepared to purchase a couple new buffer boards to throw in it, but I am nervous I've ruined my new SC board already. I disconnected the buffers and jumpered SC50 to see if the SC is bad and checked SC2 for shorts. No shorts and remains 7 blinks. Is there anything that I'm missing here? I also did the resistance checks as follows :
Using a digital meter
measure the resistance
between VF-ground
(Floating ground) and
pin 2 of connector SU41
on the SU board.
The normal resistance
should be approximately
2.1Mega-ohms.
Note: A low resistance
reading indicates a
defective SU board.
I got .799M ohms with meter set on auto black to ground red to pin 2, swapping the leads red to ground black to pin 2 yields 18.50M ohms
Using a digital meter,
between VF-ground
pin 9 of connector SD42
on the SD board.
2.1Mega-ohms.
reading indicates a
defective SD board.
I got .799M ohms with meter set on auto black to ground red to pin 9, swapping the leads red to ground black to pin 9 yields 19.80M ohms
Using a digital meter measure the
resistance between the VF-ground screw
(Floating ground) and pin 3 of connector
SC42.
Also measure the resistance between
the VF-ground screw (Floating ground)
and pin 5 of connector SC42 on the SC
board.
The normal resistance for pin 3 is
approximately 2.9Kilo-ohms and approx.
5.7Kilo-ohms for pin 5.
Note: A low resistance reading indicates
a defective SC board.
I got 2.953M ohms on pin 3 and 5.70M ohms on pin 5...seems normal
I guess it just really bugs me that i can't get the 7 blink to change to something else as if im not isolating anything when I clearly am. I really want to fix my first TV. Please help me not waste money and hopefully determine that I haven't wasted the money I've just spent on this new SC board. Thank you so much in advance!
between VF-ground
on the SU board.
2.1Mega-ohms.
reading indicates a
defective SU board.
between VF-ground
on the SD board.
2.1Mega-ohms.
reading indicates a
defective SD board.
SC42.
board.
