Sharp LC-60SQ15U TV DPS-167CP - No power
Re: Sharp LC-60SQ15U TV DPS-167CP - No power
Originally posted by R_J View PostPC7904 is used to turn on Q7902 to supply vcc_on so it can be left out of circuit for now.
If you also remove pc7903 and D7908, pin 4 of ic7903 should be about 7volts, If it does not come up, try isolating just pin4 from the circuit trace, this will eliminate any other component on that line as well.
Originally posted by R_J View PostHere is the block diagram of the ic I have no idea why you have 0 volts on pin4
Is R7918 (0Ω) open?
Are these NEW ic's or used?
Does it make sense to desolder the supervisor? Or can I just remove the resistors on pins 1 and 3? I read on other forums that it happens to be a common problem his of not give starting ICLast edited by romasik; 05-21-2022, 05:41 PM.
What do you have in place for D7950? Maybe disconnect whatever is in there and see if the vcc comes up.
The ic's startup cell IS providing the initial 9volts, (at low current) so there can't be anything on that vcc line killing the voltage or you wouldn't have 9v. something is keeping the ic from oscillating.Last edited by R_J; 05-21-2022, 06:43 PM.
Originally posted by R_J View PostWhat do you have in place for D7950? Maybe disconnect whatever is in there and see if the vcc comes up.
Originally posted by romasik View PostHello, please help me i have same problem on my Sharp Aquos 60LC635E No 5V power, tv dead . Blown R7900 and short D7950 . I changed it, than blown R7900 again . D7950 ok. I change IC7903 and cap on 5 leg 50V 47u and R7900 never blown again but 5V not( I do not know what to do . On big two cap 315V, on 5 leg IC7903 9V this very low for start A6069H . Datasheet say min 13V.
Please Help me. board power supply dps-162KP B RUNTKA932WJQZI assume no responsibility for any stupid suggestions I might post.
I aquired this TV to attempt to fix. Found the R7900 open and D7950 diode shorted. Replaced both (5A diode only available) and this immediately popped IC7903 with a SNAP! Did the 5A diode cause this? There was nothing hooked to power board when it popped. I poked around some more and found D7904 looks to be shorted as well. I measured the pins on the T7901 and they all look good with no internal shorts across its individual windings. Where next? I saw where you can substitute a different style 5V regulator to the IC7903 with adding a resistor to one of the legs. I didnt check the SMD side for any damage, just a very quick repair of the 2 parts i initially found to be faulty.
