Help with Toshiba 50L2300U
  • 2many
    • Jul 2016
    • 28
    Hi, Need help on a 50" Toshiba L2300U series LED TV. Less than 3 years old and the LED back light just went out. Has sound and picture (with a flashlight). I got the front bezel and back panel off (what a pain!). I poked around the power supply board near the LED power connector with an ohmmeter and found 2 shorted Schottky barrier diodes and a shorted N channel Mosfet (I have some experience in electronic circuitry but not with LED TV's). I could not get the exact p/n replacements but replaced them with components that are higher spec in volts and current.
    Unfortunately, I did not take any voltage measurements before I replaced the 3 bad components. After plugging in the power supply board, the unit would not power up with the remote or the power button on the main board. I took power supply voltage readings at the connector and they are as shown below. I am not sure what to do next to get the TV to power on to see if replacing those 3 parts helped. When the front bezel was pryed off, the IR sensor and LED indicator connector just ripped off. It does not look damaged. I have not tested continuity of the wires at the IR sensor or LED indicator but will do so. Any help appreciated.
  • 2many
    • Jul 2016
    • 28
    Re: Help with Toshiba 50L2300U
    Double post. Sorry mods, please delete this one.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
    • ju123
      Toshiba Satellite C50-A won't power down
      by ju123
      Hi guys,
      So, I've been racking my brains on this one.
      I have a Satellite C50-A which I'm repairing for a friend.
      I recently replaced the main board due to failure.
      Following this, absolutely everything works perfectly, except for the fact it won't power down.
      Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
      01-07-2022, 04:40 PM
