Samsung un55d6050 red light blinking 2 times and wont turn on
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung un55d6050 red light blinking 2 times and wont turn on
    as per budms post 18 it looks like your psu is fine you need too look on the mainboard now for any signs of burnt parts etc we have saw it where mainboards have failed due to power surges etc.
    • Dustin Reeder
      • Jun 2016
      • 25
      • usa
      with tv unplugged the green one reads zero both ways, in ohm mode with k beside it... the diodes read .24 and .36 both ways when swapping leads. I have a fluke 87 111 true rms multimeter I'm using... I have inclosed pictures and numbers of what I have found
      • Dustin Reeder
        • Jun 2016
        • 25
        • usa
        the chip looks burnt to me and it is bubbled feeling to the touch its number isIC601
        • vinceroger69
          • Mar 2012
          • 6714
          your pictures 2 and 3 we cant see as the flash makes the picture too bright
          with those diodes if you have a soldering iron you can unsolder on side from the board then lift the leg and re test regarding the resistor can you see the colour bands? what are they if you can then we can work out what it should be.
          edit! if that chip is burnt maybe its caused more damage to the mainboard maybe if a replacement board is cheap enough just change it.
          • Dustin Reeder
            • Jun 2016
            • 25
            • usa
            gold,red,purple yellow from left to right on resistor
            • Dustin Reeder
              • Jun 2016
              • 25
              • usa
              #26
              • Dustin Reeder
                • Jun 2016
                • 25
                • usa
                #27
                sorry
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  resistor 4.7k if the colours are right
                  as per the ic budm may have some ideas on if its worth trying a replacement if we can work out the part number etc
                  • Dustin Reeder
                    • Jun 2016
                    • 25
                    • usa
                    #29
                    bought these in hopes one would work from someone who just passed away..
                    Brand Part # Board Price (Range) QUANTITY COMPATABLE WITH
                    SAMSUNG SS1Q260WA(GH199A) BACK LIGHT INVERTER $ 40.00 1
                    SAMSUNG 42U2P_XM MAIN BOARD $ 50.00 2 ELEMENT-ELPCF421 INSIGNIA-42P650A11 SAMSUNG PN42C430A1DXZA VIORE-PD42VH80 BUSH-PT42GY638EB RCA-42PA30RQ SAMSUNG-PN42C450B1DXZA SAMSUNG-PS42C450B1WXXU
                    SAMSUNG BN44-00499A PD55AV1 POWER SUPPLY $ 25.00 1 UN50EH5000FX2A UN50EH5300FX2A
                    BA31MOG02021 1
                    PANASONIC TNPA3903BAS DG BOARD $ 75.00 1
                    LG 47LES400-VC 1
                    SAMSUNG V320HK-CPE1 T-CON BOARD $35-$45 1
                    TOSHIBA PE0248A1 VIDEO BOARD $ 45.00 1
                    SAMSUNG BN96-25758A MAIN BOARD $40-$55 1 UN5OEH6000FX2A
                    SAMSUNG BN94-00923A MAIN BOARD $85-$100 1
                    BA3AFOFO1 02 2 1
                    PANASONIC TNPA3761 POWER SUPPLY $ 40.00 1
                    VISO M470VSE DPS-129DP POWER SUPPLY $35-$65 1
                    LG 47LE5400-UC POWER SUPPLY $100 1
                    SAMSUNG BN96-19471A MAIN BOARD $60-$75 1
                    LG EBT63706701 MAIN BOARD $ 60.00 1
                    PANASONIC TNPA3769 VIDEO BOARD $ 15.00 1 TH-37PX60U TH-42PX60U TH-50PX60U TH-58PX60U
                    PANASONIC TNPA3822 BUFFER BOARD C2 $ 25.00 1
                    PANASONIC TNPA3B29 AC1D LOGIC BOARD $ 20.00
                    RCA 42RE01TC81ELNA2-A1 VIDEO BOARD $ 50.00
                    SANYO/HITACI PNEL-T902A INVERTER BOARD $ 20.00
                    SAMSUNG 42U2P-YB MAIN BUFFER BOAED $ 80.00
                    SONY V144-X01_YB INVERTER BOARD $ 80.00
                    PANASONIC TNPA3824 BUFFER BOARD C4 $ 15.00
                    PANASONIC TNPA3825 BUFFER BOARD C5 $ 15.00 TH5OPX6OOU
                    ELEMENT ELDFTT404 MAIN BOARD $ 50.00
                    SONY BTF-CA4112 MAIN BOARD $ 30.00
                    VIZIO DP5-26OJP POWER SUPPLY-BACK LIGHT INVERTER $ 40.00
                    PANASONIC ETXMM610MEF POWER SUPPLY $ 100.00
                    PHILLIPS 39PFL2608/F7 $ 54.00
                    VIZIO PSU50X4-L1 POWER SUPPLY $150-$176
                    LGE (VIZIO) PDP 060915 LOGIC BOARD $ 39.00
                    LGE (VIZIO) BR36906201 YSUS BOARD $ 148.00
                    VIZIO PD50LT_M3.BRD
                    VIZIO 3850-0012-0187 (5A) TUNER BOARD $ 50.00
                    LGE(VIZIO) PDP TYDRV TP VYDRVTP YDRV TOP BOARD $ 30.00
                    LGE(VIZIO) PDP07020 YDRVBT BOTTOM BOARD $ 30.00
                    VIZIO 3850-1O102-0150 (3A) PDP MAIN BOARD $ 33.00
                    SANYO PSPF561A01A POWER SUPPLY $ 150.00
                    SANYO 50JDW2 ;K41-04220A LOGIC MAIN $ 30.00
                    SANYO PWB MAIN N4PE MAIN BOARD $ 50.00
                    SANYO CCP-3400
                    SANYO LJ92-01443A/B/C/D/E/F/G E BUFFER BOARD $ 15.00
                    SANYO 50HDW2YB (LOW) & 50HDW2YB(UP) YB HIGH AND LOW BOARD (SOLD TOGETHER) $ 70.00
                    SANYO 50W2Y-MAIN (2L) Y MAIN BOARD $ 100.00
                    SAMSUNG LJ94-03344E T-CON BOARD $35-$50 BN81-04355A BN81-05772A BN81-04159A BN81-04401A BN81-04352A
                    SAMSUNG BN94-04472B MAIN/VIDEO BOARD
                    TV Board Inventory.xlsx
                    Displaying TV Board Inventory.xlsx.
                    • Dustin Reeder
                      • Jun 2016
                      • 25
                      • usa
                      #30
                      the sheet above is what I bought and the info there I guess is what he was charging for them......
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #31
                        It looks like Yellow, Purple, Orange, Gold to me which is a 47K resistor
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #32
                          I would suggest you lift one end of each component and then measure.
                          Diodes using meter set to diode check and resistor set to ohms range.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #33
                            The backlight stays on when he removes the mainboard cable so power supply is working. Power surge is most of the time a fried mainboard as the power comes in via a hdmi/cable connection. ( Lightning causes that for example ).
                            you could try and replace that ic but if that ic is bad , there is a good chance that other ic's like the hdmi controller chip has gone to.
                            If you have a similar board with same connections , try and see if the tv turns on. For example Samsung 40D5000 mainboard works also in 40D5500.
                            • matty24
                              Samsung UE50MU6172 - red light blinking
                              by matty24
                              Hello. I have problem with Samsung UE50MU6172.
                              TV won't turn on, red standby light is blinking.
                              Power supply BN44-00807A is fine. I replaced it with the new one.​
                              Main board BN41-02568B (BN94-12530E)
                              I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                              03-02-2025, 08:57 AM
                            • Fergal22
                              Samsung UE40F5300AK blinking red light
                              by Fergal22
                              I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                              When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                              I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                              Any help would be appreciated...
                              02-02-2023, 09:19 AM
                            • norbiszoke
                              Samsung 50AU7172, only blinking red light
                              by norbiszoke
                              We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                              Regards, Norbert!...
                              04-17-2024, 06:54 AM
                              09-07-2024, 05:50 AM
                            • 3DDD
                              Samsung UE46D6100 LED TV blinking red light indicator
                              by 3DDD
                              Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                              02-20-2025, 12:51 PM
