Samsung LE37B652 Fix: Delayed Startup (10-30m)
  • strtfr
    • Jul 2016
    • Netherlands
    This post is a heads-up and fix for forum members experiencing resembling problems.
    Brand: Samsung
    Model: LE37B652
    PSU: BN44-00261A
    Symptoms: After connecting the television to the mains power supply the red standby led indicator lights up. As soon as the power button on the remote control is pressed the standby indicator turns off and stays off. The LE37B652 does not immediately respond to power-on and seems disconnected from mains. It's possible that a subtle whining/clicking noise emerges from the back of the LE32B652. Only after 10m/20m/30m/40m does the LE37B652 power on and starts-up.
    Identification: This model suffers from the bad capacitors problem. There may or may not be capacitors visible which are leaking or slightly expanded at the top. Although this is a common sight, my capacitors indicated no such problems and looked alright. The LE37B652 turns on immediately after warming up the capacitors around CM876 & CM881 with a heat-gun.
    Solution: Replacing all 10uF/50V (1, CI801), 47uF/50V (5, CM854, CM871, CM867, CM869, CM853), 1200uF/10V (1, CM852), 1000uF/25V (2, CM881,CM876) 105C capacitors did solve the problem in my case. I had them at hand, so replaced all at once.
    Result: The standby LED turns on after connecting the television to mains. The standby indicator will dim and intermittently blink (5s) as soon as the power-on button is pressed on the remote control. LE32B652 turns on, problem solved.
    Good luck.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Samsung LE32B652 Fix: Delayed Startup (10-30m)
    Welcome to the forum and thanks for the detailed fix.
    • strtfr
      • Jul 2016
      • Netherlands
      Your comment is highly appreciated. Thank you very much and have a nice day.
        09-07-2024, 05:50 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
