Any Tips on Repairing Edge Lit LED Strips?
  • SLK001
    • May 2014
    • 264
    I have a Samsung UN46ES6150F that has multiple LEDs blown. The LEDs are the vertical mounted edge types. There are only two strips, each with 60 LEDs, on either side of the panel (it is one of the thin panel TVs).
    I have ordered the replacement LEDs from AliExpress, so I have about 3 weeks to come up with a decent rework proceedure for these LEDs. I have two soldering stations and a Weller heat gun, both of which I have used to remove LEDs from horizontal strips, but I can't think of an easy way to use either of these for the vertical mounted devices.
    I was wondering if anyone had a successful proceedure that they used for these LEDs.
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Any Tips on Repairing Edge Lit LED Strips?
    I am doubtful that you have ordered the correct LEDs for these strips? I think they are twin unit LEDs that are side mounted to the strip? But if they are the correct type please let us all know the seller on Allexpress. As for fitting first you must remove the LED strip from the heat sink board, then using hot air to the rear of the strip remove the LED,do not remove the old solder from the board, and use lots of flux fitting the replacement and make sure to fit them the correct way round. Good luck
    • mmartell
      • Oct 2013
      • 3189
      I have the 55" version of this tv. Fully half of the 76 leds on the left hand strip are shorted and these strips are hard to come by.
      • Diah
        • Feb 2013
        • 6613
        it would be nice if you post photo of the Original strips, and show us the print label of the strips.
        • mariushm
          • May 2011
          • 3799
          Paint stripping guns / hair dryer / heat gun does wonders.. heat the aluminum strip from the bottom and if requied, apply solder iron on top on the led terminations.
          Replace with led of same forward voltage.
          Alternatively, if you can't find a led with same forward voltage, a trick would be to use a zener diode with that voltage rating - or a led with lower forward voltage and a zener diode in series with the led.
          I first saw this trick with the zener diodes on norcal715's youtube channel, here's a two part video where he fixes a backlight this way:
          part 1 : https://www.youtube.com/watch?v=hh3z_dkkcUM (jump to around 10:00 if you're impatient, first 10 minutes is debugging, explanations etc)
          part 2 : https://www.youtube.com/watch?v=8otPjsN8jD8 (removing led, installing zener diode in its place etc)
          • capwizard
            • Jun 2016
            • 1991
            Look at this!
            LED Pick & Place Machine Model EML 61D
            https://www.youtube.com/watch?v=Y45COU2LdXg
            High Speed Automatic LED Chip Mounter
            https://www.youtube.com/watch?v=5XyFYHdmuLM
            This is what you need [Hot air method]
            EEVblog #415 - SMD Stencil Reflow Soldering Tutorial
            https://www.youtube.com/watch?v=qyDRHI4YeMI
            The best one [Hot plate method]
            LED Solder Station
            https://www.youtube.com/watch?v=-usEBCBXOqs
            Edge Lit LED Strips start at 3.59
            I try to make one from soldering iron tip, which inserts inside a metal block,
            control the temperature to 250c..... constant temperature of 250c and A toothpick, that's the points
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
              LENOVO ThinkCentre Edge 71 ThinkCentre Edge G630 Specification for Upgrade or Repair
              This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-12-2024, 03:36 PM
              LENOVO ThinkCentre Edge 71 ThinkCentre Edge i5-2400S Specification for Upgrade or Repair
