Panasonic TH-C50HD18 no picture
  • 73buick
    • Mar 2011
    • 41
    Client brought in this TV, it got hit w/a lightning surge. When you plug it, relays click. Hit power button, more relay clicking, but nothing on screen. The red power led is steady on and both green leds on the SC and SS boards are steady lit. Initial check of the Vsus, Ve, etc are all within parameters according to the service manual I have.
    What should I test for next? I am assuming one of the smaller boards is bad?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-C50HD18 no picture
    sounds like mainboard. If it's powering up and the sustain boards are running then mainboard .
    • FZG
      Panasonic AG-1000B VHS player with bad picture quality
      by FZG
      Hello!
      I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
      Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
      I want to know, is this something that could be solved by recapping or is the video head likely gone?
      Also, what mechanism is this?
      Any feedback is appreciated!...
      05-06-2024, 07:16 AM
    • Bazfletch3
      Panasonic TH-65FX800A backlight LED's working but picture is very dark
      by Bazfletch3
      Hi all
      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
      From there I envisaged that the backlighting wasn't working, however...
      01-08-2024, 10:18 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • Buzztv
      Panasonic TC-P42S60 Plasma,how to check Vsus
      by Buzztv
      This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
      About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
      I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
      I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
      10-27-2019, 01:24 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
