Samsung UN60EH6003F horizontal line
  • kakureru
    • Aug 2013
    • 4
    • usa
    can anyone confirm weather this is a panel issue or a tcon issue? the line gos completely through the screen and I have already tried messing with the tabs and other connections to get a reaction. Dont want to spend money on a tcon board if it not likely a solution.
    the color of line fades to the dominant color of the vertical axis of whatever part of the line.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN60EH6003F horizontal line
    Panel failure not fixable sorry
    • kakureru
      • Aug 2013
      • 4
      • usa
      ug ohwell. thanks.
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
        09-07-2024, 05:50 AM
      • kotel studios
        Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
        by kotel studios
        Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
        In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
        Yesterday, 02:07 AM
      • yankys
        Samsung 75"QN75Qn90AAFXZA Horizontal line
        by yankys
        Hi, everyone this 75" has horizontal lines and jittering I did a visual check on the ribbon cables and reset them still same results it will work for awhile then reboot and play again, could it be a main board given that the t-con and main board are one....
        01-29-2023, 09:17 PM
        09-06-2024, 11:40 PM
