40PFL5505D/F7 power cycles
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I am working on Phillips 40PFL5505D/F7.
    When you plug the TV in, the status LED blinks 12-14 times (I guess that is normal start-up sequence), then turns solid, black-lights come on, no picture, no sound at any time. The back-lights stay on for 4-5 seconds, then TV shuts down, status LED turns off, and TV immediately restarts with 12-14 LED blinks, and then precedes from the beginning over and over. Pressing the power button does not interrupt the sequence at any point. Yes the LED blinks vary from 12-14 blinks before the LED turns solid.
    Power supply provides constant and uninterrupted 5.3V stand by voltage. PSON reads 3.5V at all times, but at the time when back-lights turn off and TV restarts itself. BL_ADJ2 and BL_SW show positive readings at the time the back-lights are on and they are off rest of the time.
    I have disconnected the inverter and T-Con, but the sequence is the same. The T-Con fuse is OK, and it does receive 12V, but only at the time the back-lights are on. Looking at the screen in the dark, I see no discolorations of the light on the panel, so CCFLs are most likely OK.
    Any thoughts?
  • saddle_au
    Waste Warrior
    • 121
    Re: 40PFL5505D/F7 power cycles
    Disconnect the IR and switch cable CN3004 as well, sometimes these can cause issues. This cable goes to the IR board and daisy chains to the switch board.
    Check the voltages (and their purity) on the caps and regulators circled in red. IC4602 takes in 12v (pin 2) and switches it down to 1.2v, switcher and inductor is on pins 7/8. IC4604 takes in 12v (pin 2) and switches it down to 3v3, switcher is on pin 3. IC4601 takes in 12v (pin 2) switches on pin 3 and makes 2.7v. It feeds a couple of other regs, IC4603 and IC3603 both 1.8v regs.
    Check the reset chip IC3103 on pin 4 to see if it toggles before the power off.
    Slightly heat IC3102 to see if it makes a difference to the boot. Its the settings eeprom.
    Get the schematic from http://www.electronica-pt.com/esquem...artdown/24955/
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      4602: 12V on pin2, but 0V on either pins 7 or 8
      4604: 12V on pin2 and 3.3V on pin 3 that toggles to 0V during reset
      4601: 12V on pin2 and 2.7V on pin 3 that toggles to 0V during reset
      3103: I can't find this IC
      Good idea bout disconnecting the IR, I did not think of that. Sadly, no change.
      I did pre-heat the EEPROM and the SMD capacitors before with no change.
      • saddle_au
        Waste Warrior
        • 121
        The Inductor L4602 attached to the switcher reg IC4602 should have 1.2 volts on it to feed the frame rate chip. One side should look like noise and the other 1.2v. As long as there's 12v it runs.
        What you are describing could also be bad BGA connections, although I see that lots in LG, not as much in Philips.
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
        • htv239
          LG UH8500 Backlight Troubleshooting Help
          by htv239
          I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
          Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
          What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
          10-11-2021, 01:53 PM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • max789
          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
          by max789
          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
          I made the following tests:
          1. Disconnected the main board from Power Board = backlight works.
          2. Connected the main board and disconnected the T-Con = backlights does not work.
          So I ordered a main board from Ebay also BN41-02156A but from...
          01-18-2024, 06:56 AM
        • bpcannan
          VIZIO M557-G0: Backlights or ???
          by bpcannan
          'Morning,
          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
          10-29-2023, 06:36 AM
