Samsung PN50C490B3DXZA Plasma TV Lines
  • planetcadillac
    • Jun 2016
    • 4
    I am working on a 50" Samsung Plasma TV about 5 years old. It has a bar that is prominent when you first turn on the TV that eventually fades and may disappear after some time. It is a vertical bar always in the same spot. Otherwise the TV operates as it should with all functionality. I have attached an image of the problem.
    I have worked on many things but this is my first plasma TV. I am in the process of removing the Y buffer which is easy to access and sits vertical on the left side of the TV board. That is the easiest buffer to remove. Parts list shows a X buffer but its buried at the bottom along the support strip for the stand, etc. Looks to be a bit of a chore to remove. I cleaned the TV from dust, etc. and checks for visual problems and none found so far. No obvious blown ICs, burn marks, etc. I am going to check resistance on as many of the boards I can access. The X board, if it has one, is buried deep.
    Thoughts?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN50C490B3DXZA Plasma TV Lines
    It looks like a bad tab on the panel. I have seen many with black lines. This is the first white line I have seen. Maybe tom66 will chime in.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      COF Chip on tab--Part of panel, Unrepairable.
      TELEFIX
      • Diah
        • Feb 2013
        • 6573
        +1 you can handle it with easy light push on tap to keep it stable no line there.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          RUBBISH!
          Its the COF on the tab. Its Stuffed and no amount of shoving pressing or other pressure is gonna cure it!
          Its a cruddy C Series Samsung PLASMA set--NOT LCD!!
          I Just Dispair sometimes.....
          TELEFIX
          • planetcadillac
            • Jun 2016
            • 4
            Thanks guys.
            Well that is the worst of it when it turns on. After a couple of minutes it will dissolve and then disappear. Most problems that I have found due to bad ICs and broken bits the problem is steady.
            Here are a couple of pics in better condition.
            Thanks!
              09-07-2024, 05:50 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • xNOTx
              Verticle lines on Samsung PN42A400 Plasma TV
              by xNOTx
              Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
              [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
              04-30-2024, 04:22 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
