Sony kdl46ex723 Read Only Service Menu
  • antonvp
    • Jun 2014
    • 5
    • canada
    Hi All,
    I had a mainboard (BATV) fail for a second time now (every 2 years as if it's on a timer) on our kdl46ex723 tv and this time I got a 1-883-753-22 A1814571B board from ebay and replaced it successfully, tv is working now.
    It came from a 40 inch kdl40ex720 TV and after firmware flash sony_tvupdate_2011_4027_aaa_auth.zip it started working fine on my 46in tv. WiFi and 3D are both working but when I go to the service menu the model is still displayed (IN RED) as kdl40ex720 and when I change it to kdl46ex723 it becomes green but I am not able to save the changes via pressing MUTE and then ENTER (the round button) it appears as if the settings are read only and it would not allow me to save the changes.
    Question: Does anyone know why MUTE and Enter would not commit the changes and how to bypass the read only settings?
    And is there any harm or downside to have the board operate as a kdl40ex720 on a 46in model (Panel: LTY460HJ05-A01) ?
    Thanks,
    -A
  • Diah
    • Feb 2013
    • 6614
    Re: Sony kdl46ex723 Read Only Service Menu
    first you need to start with yours original serial No to registered it at the NVM, then the model. also can use J-TAG via terminal to write all on NVM,
    you are now safe dont worry
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Jtag or serial?
      • Diah
        • Feb 2013
        • 6614
        Originally posted by Malachi
        Jtag or serial?
        jtag via serial
        • Diah
          • Feb 2013
          • 6614
          windows terminal = serial
          • antonvp
            • Jun 2014
            • 5
            • canada
            Hi There,
            Thanks for your answer, I am still not able to change the serial number.
            I get to the menu and then sub menu:
            S/N
            *1 30XXXXXX
            But not able to enter new values... Is there a trick how to update the S/N?
            Also I wanted to ask if there is a sony manual available for service menu as all these settings and the UI itself are not very user friendly...
            Cheers,
            -A
            • antonvp
              • Jun 2014
              • 5
              • canada
              jtag via serial
              Do you happen to have the jtag pinout / levels etc for that?
              Is there anything that can edit / interpret the dump?
              Thanks,
              -A
              • R_J
                • Jun 2012
                • 9632
                I doubt this will help but it might be worth a look?
                • antonvp
                  • Jun 2014
                  • 5
                  • canada
                  Good stuff!
                  It is a fantastic manual, exactly what I was looking for!
                  New board is married to the rest of the tv now (except serial # which I don't care at this point since I will never call sony again )
                  To write is MUTE and "0"
                  Thanks!
                  • Diah
                    • Feb 2013
                    • 6614
                    thanks for the upload. very useful
                      LCD LED TV Service Menu Codes
                      TCL LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      10-31-2024, 03:58 AM
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                      09-06-2024, 05:30 AM
