LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
  • JDC
    replied
    Re: LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
    Originally posted by dick_barton View Post
    Did you manage to follow the wiring back from the Tcon fuse back to any component on the main board. You said earlier that the 12V on the Tcon fuse was missing?
    I haven't yet, no. You are referring to the F1 fuse on the TCON?
  • dick_barton
    replied
  • JDC
    replied
    Originally posted by CapLeaker View Post
    O.k., you measured GND, 12V, 12V GND, 24V, GND, 3.5V, 3.5V and PWR-ON.
    Where are the GND, NC, 12V, GND, 24V,GND, PDIM2, PDIM1 and DRV-ON measurements?
    Yikes! I see what I did wrong now. I'll get back to you. Thank you for being patient.
  • CapLeaker
    replied
    Originally posted by JDC View Post
    ON
    -.009
    12.13
    12.13
    -.01
    24.48
    -.011
    3.51
    3.51
    3.104
    OFF
    0
    .009
    .009
    0
    .006
    0
    3.55
    3.55
    0
    Attached is a diagram for the connection from the power board to the main board. It says:
    P201
    GND GND
    12V N.C.
    12V 12V
    GND GND
    24V 24V
    GND GND
    3.5V PD1M2
    3.5V PD1M1
    PWR-ON DRV-ON
  • charis
    replied
    If your backlight start and the panel stay black is T con problem.
    Usualy this symptoms happen to samsung tv but the sound works.
    Try to heat the main processor and see if you have picture untill he cools .
    Also check the regulators near processor specially the 5v and VCC.
    If nothing happen your tcon is faulty.
    To test Tcon jump 12v from SMPS to the Tcon fuse.Disconect the LVDS cables Jump VCC 3.3v to the LVDS(CN1) connector ground pin.Aply ac to power supply, patterns of White, Red, Blue, Green
    should appear on the screen.Voltages can be read at the ribbon connector or at test locations on the board (typical 16.74V, 3.3V, -5V and 28V)
  • JDC
    replied
    Originally posted by Diah View Post
    from yours T-CON photo it show to me the left ribbon cable not correct sitting at the panel socket., take them both out and check the Gold pins of them, then reset them correct, as they labeled with hand writing they seem had story.
    Reseated, nothing out of the ordinary I could see, still no change. Thanks anyways.
  • JDC
    replied
    Edit
    Please can you provide some sharp picture of your main board which would be of help.
    Is this better?
  • JDC
    replied
    Those are only half of the pin outs. There are 18 of them in total. We need all of them plus the pin out name!
    However... there is no voltage going to the Tcon. no voltage there, no pic. Maybe disconnect the tcon and see if the voltage re appears on the connector.
    ON
    -.009
    12.13
    12.13
    -.01
    24.48
    -.011
    3.51
    3.51
    3.104
    OFF
    0
    .009
    .009
    0
    .006
    0
    3.55
    3.55
    0
    P201
    GND GND
    12V N.C.
    12V 12V
    GND GND
    24V 24V
    GND GND
    3.5V PD1M2
    3.5V PD1M1
    PWR-ON DRV-ON
  • CapLeaker
    replied
    Using the main board pic I posted above as reference, from left to right:
    ON
    0
    12.13
    12.13
    0
    24.47
    0
    3.47
    3.47
    1.107
    Off (but plugged in)
    0
    .007
    .007
    0
    .004
    0
    3.55
    3.55
    0
    F1 fuse on TCON:
    ON .014 both sides
    OFF 0 both sides
  • Diah
    replied
  • dick_barton
    replied
    You appear to have no TCON voltage, so no picture. You need to follow the wiring back to the mainboard and find the supply. Use your meter to trace the connection from the TCON fuse down to the mainboard. The TCON supply is probably supplied from a switched transistor or mosfet that I suspect has been blown.
    Edit
  • JDC
    replied
    Originally posted by nicholas1110 View Post
    I have had the exact thing happen to me on one of the first ones I've done LEDs on this model. Here is what happened to me. I take the tv down to the LEDs. Repair the LED strips as needed. I turn the tv on to check that all LEDs are working and rest the tv on the bottom edge. No I did not disconnect the tcon from the main board l, so when I tipped the tv up the ribbons to the panel touched the metal frame and shorted a component out on the main board. It was near the lvds connections smd square ic chip. So if you left the tcon plugged in and the ribbon cables in the tcon and tipped the tv up I would almost bet you shorted out the main board or something on the tcon from the ribbons touching the metal frame. If you took the ribbons off or unplugged the lvds cable then disregard my suggestion
    I took the ribbons off the TCON when I was taking it apart but the connection from the TCON to the main board was left alone.
  • JDC
    replied
    Umm... first off your pics are blurry.
    Now there is a ribbon cable going from the PSU to the main board. There is a pin out on the PSU. Measure all those with the TV on and off and post the measured DC voltages with the corresponding pin out name.
    Also try to turn on the TV and measure both sides of F1 on the Tcon against cold GND.
    Report back.
    ON
    0
    12.13
    12.13
    0
    24.47
    0
    3.47
    3.47
    1.107
    0
    .007
    .007
    0
    .004
    0
    3.55
    3.55
    0
    F1 fuse on TCON:
    ON .014 both sides
    OFF 0 both sides
  • nicholas1110
    replied
  • CapLeaker
    replied
    Report back.
  • JDC
    replied
    Bump.
  • JDC
    replied
    We need to see the pictures of the whole back side of the TV to see how all the boards are connected together, then we need the picture of the T-CON board.
    Here you go. I took a closeup of the TCON fuses as well.
  • ReeceyBurger123
    replied
    Didnt mean to comment on thread.
  • JDC
    replied
    Originally posted by ReeceyBurger123 View Post
    Delete.
  • ReeceyBurger123
    replied
    Delete.
