Re: Enlight 32" HD LCD TV / Barebone PC (TVL-322 TC3200) Intermitent Power Up
I would change those ten (10) Bad caps and give it a start-up. I believe that should solve your problem.
Is that what/where you mean?
I wonder if that could be causing my issue..?Leave a comment:
Also I will screen shot them when I get home (at college now) but look up how to find bad capacitors on Psu and you will know what to look for.
By PSU do you mean the light brown/yellow circuit board part? If so, where abouts on that are bad caps?
Cheers! Adam.Leave a comment:
Wow that's a weird Tv lol. Your Psu also has some badcaps on the secondary side. If you can see them ?Leave a comment:
On the main board (second picture bottom left and right) are 2 socketed flash roms. Take them out and reseat them. See if that cures your problem.Leave a comment:
Hi the images have not attached please upload them using the attachment feature.Leave a comment:
Hi everyone in the know! :-)
I've been having an issue with my 'once trusty' 32" TV/PC it's a bit of a unique take on a TV this one and I doubt they sold many of them back in the day but basically it's a 32" TV with a (poor by todays standards) 720p panel and room in the back for a MicroATX motherboard of sorts, a 3.5" hard drive and comes with 2 Asus TV cards...
I originally purchased it about 6 years ago brand new as a barebones unit for around £200 at the time which was mega cheap for a 32" tv, the catch back then was that you needed to build a PC into it to make it work... As I was an IT tech back then I had plenty of knowledge so wasn't bothered, I chucked a 3GHz Core2Duo in it, 4gb DDR3 ram, a 1tb 3.5" Samsung spinner and a 128gb OCZ Agility 3 SSD soon after for Windows to boot as fast as possible from.
Right, that's the introduction done, I do still use this TV and it's since been upgraded to Windows 10 and it still flies to the desktop with the above spec and mainly use it with Plex and Kodi etc... (So I would like it still working ideally and I'm not quite ready to bin it...)
The problem.
It started happening around 6 months ago, when I first turn it on, I hear the CPU fan spin up, the PSU, the hard drive it's all go, the screen back light shows up but nothing on the screen at all, I hear the Windows start up sound through the speakers so I know it's booted up fine.
6 months ago, I would then press the power button a single time which would then make Windows do the proper shut down procedure, once it was powered off, I'd then press the power button once more and it would all be working again...
6 months on to today, it's basically doing the same thing except it takes 3 power cycles to get the screen to actually display anything...
Things I've tried so far, I initially thought it might be something to do with the PC hardware side of it, so I've tried a brand new PSU (even though my tester said the original is fine, I had one available...) I've also tried a completely different Motherboard, Ram and CPU setup still nothing. So now I'm thinking it's obviously something to do with the TV side of things, which I have no clue about...
Also, I get no source selection until the 3rd power cycle, so that also re-enforces that it's not the PC side of things as I can't even select HDMI, SCART etc until it's happy...
I've looked all over the 2 circuit boards for anything obvious and I can't see any inflated CAPS so I've taken a few pics if anyone could have a look and tell me where to start maybe or if anybody has any experience with the above symptoms maybe (switches on, back light is on, no picture until 3rd power cycle...)?
Thanks in advance guys!!!
Adam.
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 02:15 PM
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
