coby TFTV4028 main board poblem blue ligth
  • hmendez86
    • Jun 2015
    • 344
    • united states
    i have a coby tv tftv4028 and main board is the problem and i cant find the board any where.....theres three types of boards....the one that i have is 002-FV40-2810-00R with AU Optronics T400HW03 panel.......my question is can i replace it with 002-FV40-2813-00R it has the same panel....
    Coby 002-FV40-2813-00R for AU Optronics T400HW03 panel
    Coby 002-FV40-2812-00R for Samsung LTZ400HF21-W01 panel
    Coby 002-FV40-2810-00R for Samsung LTA400HM02 panel
  • Egidio85
    PS5 EDM-033 UART 80810001 Beep 1 second Ligth
    by Egidio85
    Hi everyone, I have a ps5 EDM-033 that beeps, blue light for 1 second and turns off.
    reading the error codes via uart gives the following code:
    80810001 General power failure (periphery, GDDR6, APU, data line shorted)
    checking the card I didn't find any shorts, Boot sequence is quite right 325 mA dropping to 9 mA.
    Using the thermal camera I can see the SSD controller and South bridge getting warm.
    if I press the power button the RAM also heats up, the processor doesn't seem to. in fact if I go to measure I don't have +1v CORE output....
    04-09-2025, 10:32 AM
  • Vusal
    CPU replace | OEM Hash key poblem
    by Vusal
    first of all hello everyone
    If there is a short circuit on the motherboard of the HP laptop. The CPU was broken (i3-10th) I found a donor motherboard on ebay and replaced the CPU.
    The CPU on the donor motherboard had the OEM Hash key. But I did not check the OEM Hash key before ordering the donor motherboard.
    Normally, after changing the CPU, the motherboard started and the white LED light on the DC jack was blinking.
    The motherboard was in reset state and the current drawn was 60mah.
    I checked the BIOS information and added the OEM Hash key on the donor motherboard...
    04-04-2024, 02:30 PM
  • hmendez86
    Nintendo 2ds xl blue ligth no image
    by hmendez86
    I saw some vids and said bad screen on the top, i did try d pad up and power at same time and turns on both screen but in a sec it freezes no movment at all. I turn it off and back on and does same thing blue ligth..so i know screens are good its something else...this nintendo 2ds is not brick or anything...i try disconecting the cameras and does same thing...any suggestions
    01-17-2022, 12:51 PM
  • GSMJOEY
    Coby ct4rvc1 mb v10
    by GSMJOEY
    just incase you need tested on me
    CT4RVC1_MB_V10
    09-14-2023, 10:49 PM
  • hmendez86
    coby TFTV4028 blue ligth stays on and won't power on
    by hmendez86
    Coby Tftv4028 I found a problem to that I change one regulator and it turn on good nothing wrong but the thing is when it's unplug the cord it does the same thing blue light lit but won't power on...I check the regulators and they check good... I know the main is good...theres a problem on the turn on switch and there were am lost.....there mp14280dp can be that the problem...
    04-19-2016, 09:30 PM
