Samsung LN46D630M3F, TV powers on, sound works but no backlight
  • dick_barton
    replied
    Re: Samsung LN46D630M3F, TV powers on, sound works but no backlight
    Have you measured the primary and secondary sides of the inverter transformers to check that they all have identical readings?
  • Five_magics
    replied
    QI802 and QI808 are okay (at least, not shorted). FS802S is good.
    Tested CI818's ESR which was fine, gonna check the capacitance tomorrow.
    replied
    CM801 is part of the main power supply and you are getting the 12V, etc. so that will not be the problem.
    You have power supply-inverter transformers driver board (QI802, QI808 are the power MOSFETs for driving the inverter transformers (3) board).
    Fuse FS802S for supplying the B+ to the Inverter driver circuit is OK?
    You also need to check the cap CI818 (0.47uF) to make sure the capacitance is still within 10%.
  • Five_magics
    replied
    Here are pictures of the main board, power supply and inverter board.
    Took the power supply to work today to test the ESR of caps. Turns out one of the electrolytic I put in is bad (30 ohms+). Also CM801 gives no reading, wondering if that could have to do with the value? I usually measure capacitors above 1uF. You can also clearly see heat marks near it.
  • CapLeaker
    replied
    probably the inverter board.
  • Five_magics
    replied
    Like I said, with everything plugged in the backlight(CCFL) doesn't even light up. When the main board is disconnected, it lights up for half a second and shuts off.
    Will take pictures and post tomorrow.
    EDIT: Missed the stickied thread. Sorries!
  • RCA2000
    replied
    USUALLY...a BL that "lights for a couple of seconds and then drops...is the fault of the BACKLIGHTS--be they CCFL tubes of LED"S.
    Show a rear pix of panel with all boards--and I will get a better idea of things to go on...
  • Samsung LN46D630M3F, TV powers on, sound works but no backlight
    Hey! So I have this LCD TV (Samsung LN46D630M3F) which is my brother's and needs to be fixed, been out of the troubleshooting world for a while, thought I'd ask here. The set is 5 years old or so.
    Basicly, the TV powers on, plays some Samsung tune, and isn't backlit(not even for a second). From what I got told, the TV worked just fine one night, and the next morning it didn't.
    Already ordered an inverter board on a whim, until then I'm trying to see if the power supply isn't at fault. Already swapped all electrolytic capacitors, also checked most semi-conductors and they all seem fine (at least none are shorted). When everything's plugged in and TV is powered on, there's a coil whine coming from the power supply unit for half a second then it stops.
    Took some voltage readings at the inverter's connector tonight, which are;
    LD=10,8v
    13v=12,1
    CNT_PRT (current protection?)=11,6v
    OVP=0v
    GND=0v
    Also tried powering up the set without the main board connected; backlight lights up for half a second and shuts down. Tried taking readings at the inverter connector with the main board/inverter disconnected, but forgot to take notes. Will do it again tomorrow. Didn't bother taking primary readings at this point.
    After a google search, couldn't find the power supply schematic (BN44-00463A), so if anyone has it, that'd help a ton.
    Any help is welcome. Thanks!
    09-07-2024, 05:50 AM
  • ex250
    Kenwood SW-505D no sound issue and pops from time to time when it works
    by ex250
    Hello mates,
    I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
    It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
    12-29-2024, 03:27 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
    09-06-2024, 11:40 PM
