am having this problem with this small tv phillips 19PFL3505D/F7 . logo comes on then off like 3 secs on then immediately off...i check everywhere if there's anything damage and nothing i checked caps diodes and no sing of problem.....did some one had this problem with this kind of set of tv....any suggestions.
phillips 19PFL3505D/F7 logo comes on then off
Re: phillips 19PFL3505D/F7 logo comes on then off
You have to be a bit more specific than that. Explain exactly what the TV does or doesn't do. Right now it sounds like my car runs for 3 seconds and then turns off. Post hi resolution, straight shot pictures of your boards. Check if the TV actually keeps running and just the back lights turn off (flashlight test; sound keeps playing, no backlights; etc).
If you see a pic with the flashlight trick, or the sound keeps playing (just no backlights), its the inverter board.
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by conghuymsHey everyone,
I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned... -
by EchooFujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?11-25-2024, 01:54 AM
by smartyCan anyone identify logo shown below?
The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
Neither ChatGPT nor Copilot know the correct answer.
TIA1 Photo - Loading...
