Sony KDL 50W656A
  • kyonthinh
    • Mar 2016
    • 4
    Sony KDL 50W656A
    My TV started acting strange. First half left has distortion band and cloud, half right normal. Then I disassemble it, messing with lvds cable and now it is not working both them. When I turn it on, the right change but left still the same.
    My TV doesnt have t con board, since it is integrated to panel. No hope fixing it?
  • armoured_smiler
    Panasonic Tx-40cx400b top left half screen not displaying correct
    by armoured_smiler
    Trying to work out if this is TFT problem or TCon issue.
    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
    04-08-2024, 03:40 PM
  • misterhaus
    Sony XBR65x930D - left half screen is grainy
    by misterhaus
    Hi, this is my first post - so thanks in advance for any assistance.
    I have a Sony XBR 65x930D (manufactured in July-2016), which was initially showing a black screen, faint backlight glow, and played musical sounds when powered up. After some experimenting (mostly unplugging cable and re-plugging), including attempting hard-reset and firmware update, it is now showing video, but the left side of the screen is fuzzy/grainy. (See attached pic)
    I am trying to decide if this could be the T-CON board, or the DPS board.
    When I press on the upper right of the DPS...
    03-16-2020, 04:33 PM
  • Zelek11
    Panasonic Plasma screen interference on left half of screen
    by Zelek11
    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
    10-14-2022, 04:54 PM
  • Watson306
    6 Red Blinking lights (left side darker) on Sony KD-49XE8396
    by Watson306
    I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
    I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
    I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
    Many Thanks in advance.
    11-01-2022, 05:33 AM
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
