Drawing Schematics
  • tech2014
    • Aug 2014
    • 807
    Drawing Schematics
    Hi everyone. As repair techs, we all know how hard it is to find schematics for TV boards. What I would like to know is if anyone here draws there own schematics. If so, what program do you use and what process do you go through.
    Any advice would be greatly appreciated?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Drawing Schematics
    Design Spark was free but I don't know if it is anymore
    http://www.rs-online.com/designspark...-pcb-home-page
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      For reverse-engineering small sections of complicated boards--pencil and paper cant be beaten.
      --pointless messing with pc's and mouses for this sort of work--too messy and time-consuming.
      TELEFIX
        • 31011
        i draw lots of schem's, using EagleCAD.
        http://www.cadsoftusa.com/
        it's free for small pcb's and there is no limit to schematic size.on the free version!
        other people like to use KiCad
        http://kicad-pcb.org/
        totally free - i need to try it soon.
        both work on Lin,win & mac
        i found this btw.
        http://www.bigmessowires.com/2010/05/03/eagle-vs-kicad/
        it may interest you.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          If the board is multi-layer it would be difficult to reverse engineering the schematic. I think on single layer boards it would be best to use the virtual board layout like what BudM uses. Then follow it up with the actual board and ohm meter to verify the points are connected. You would print out a picture of the virtual board layout and use a red marker to check off the lines to each node. At the same time you can start drawing the schematic. So you would red check the node points after you verify it with a meter. So if you go from node point 1 to node point 2. You measure that continuity to verify, you then draw that line and then you check that line off from node 1 to node 2. You then proceed to the next line. The only other way that I know of instead of using a virtual is to keep on ohming out from bottom to top flipping back an forth starting at one node following all the lines at that one node, both top and bottom side of the board and drawing them down on a piece of paper. Then you would go to the next node and do the same thing. I would put a sticker on that node after I was done with it. I would also arbitrarily label each component so you know which one you are working with unless the manufacturer has labeled them and therefore you can use his labels.
          • Popalwali
            Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
            by Popalwali
            Hello Everyone,
            I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
            08-25-2024, 11:28 AM
          • Techmanx
            Schematics Download Site
            by Techmanx
            If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
            06-28-2023, 12:08 PM
          • snpulse3344
            USB Audio Interface - Steinberg UR 12 or similar schematics
            by snpulse3344
            I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
            03-01-2024, 01:07 PM
          • sunofra78
            iPhone 12 Pro Max Schematics
            by sunofra78
            Hi.
            Does anyone have iPhone 12 Pro Max Schematics they can share? I have the board view through ZXW... but really need the schematics.
            Thanks!...
            07-14-2025, 01:56 AM
          • JoSta
            Can somebody explane notation in schematics
            by JoSta
            I have been checking schematics for my motherboard and have difficulties to understand it. I figured that i need to replace the component designated with PQB03 on the board. In the schematics I find two entries with different components, although they have almost similar specs. I could not find an explanation for the prefixes "G1G3@" or "G2@"
            Can somebody help me?
            07-08-2025, 12:05 PM
