Samsung Ps42A410C1 turns on and of by itself
  • daniel1987
    • Mar 2016
    • 5
    • Romania
    hi my plasma tv started this morning and then after a few second it shuts down by itself and again start and so on it has no blown caps no cold soldering removed every board from the tv none has burn marks or any other marks.
    I plugged off the ribbons from x,y boards did the pin test same thing shuts down by itself.
    My psu is BN44-00206A w3.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung Ps42A410C1 turns on and of by itself
    Can you supply pictures of the circuit boards. Have you taken any voltage measurement?
    • daniel1987
      • Mar 2016
      • 5
      • Romania
      I did no measurements cuz i don't know where to begin with an i did some photos and a videoclip
      https://youtu.be/OD4Wa7uDVEY
      • daniel1987
        • Mar 2016
        • 5
        • Romania
        Photos!!!
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Unfortunately I know little regarding Plasma TV however I believe they have the various voltage you should be able to measure written on labels at the top of the screen. VA, VS and some others.
          I'm sure there are others that can help on you diagnose further.
          • daniel1987
            • Mar 2016
            • 5
            • Romania
            So today i took the tv to a guy in my city ho does have a tv repair service and the fault was in the memory of the av board .
            For thous who have problems like mine consider replacing the av board cheers
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Happy to hear that you have it working again.
              • Electronic Handyman
                • Apr 2016
                • 58
                Samsung is known for a SMD=surface mounted capacitor to fail causing the powering off and on issues.So anybody that runs into this issue and doesn't wish to replace the main board pl check the caps.Also I've found that bad connections on the PSU can cause the same issue I have repaired a couple of Samsungs with this same issue. I can't remember what the value is of this cap is right this moment but when I do recall the info I will update this post.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  +1 common issue on this model also the touch sense button board is also kown to fail on these too and pressing random buttons.
                  • joe-joe
                    • Aug 2016
                    • 37
                    • België
                    i have the same problem with my samsung ps42A410C1
                    on-everything ok for about 30 sec ,than shuts off
                    and keeps repething this!
                    anyone has a repairgide?
                    is there a possibillitie to replace the EEPROM!? and could that be the fault???
                    to get a new av board will be to expensif for me i thinkl!!
                    anyone have more tips!!!
                    thanks
                      09-07-2024, 05:50 AM
                    • Egidio85
                      Samsung UE55F8000SZ Turns on and off immediately
                      by Egidio85
                      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                      This defect happens continuously, hearing the classic click of the relay every time.
                      Power supply board BN44-00636B
                      disconnecting the mains and lamps from the power board always causes the same problem.
                      Is it normal that without anything connected this power supply turns on and off cyclically?
                      any suggestions on what to check?
                      thanks in advance
                      03-11-2025, 12:45 PM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
