Toshiba 32av713b1
  • ozy
    • Jun 2009
    • 44
    Toshiba 32av713b1
    Anybody got an eprom dump for a Toshiba 32av713b1.
    Its for the 24c32 (u609) , it uses 715g3705-m01-000-005b main board (cbpfa4bbz4s01)
    Fitted a blank ic now get power led and flashing green led on power up but no other sign of life.
    Thx
  • ozy
    • Jun 2009
    • 44
    Re: Toshiba 32av713b1
    Must have been a faulty eprom just fitted another and set powers up but the picture is bad as in the attached img. Any ideas?
      Looks like Gamma Voltage problem or the screen model does not match the main board, you will have to go into service menu mode to see if the LCD panel number match what is shown in the service menu. Notes: I do not remember how get into service mode in TOSHIBA TV.
      • ozy
        • Jun 2009
        • 44
        yea was just looking to see if it used a as15-s or equiv but it don't so looks like you could be right about panel selection just looking through service manual now but that don't seem much help.
          Does the service manual tell you how to get into ON SERVICE MEN MODE? You will probably need the original remote to enter the code to get into service mode.
          • ozy
            • Jun 2009
            • 44
            no cant find anyting in the service manual about it.
            • vinceroger69
              • Mar 2012
              • 6714
              not sure if this works
              LCDs :
              * Press the {MENU} button on the remote.
              * Highlight the "Picture" icon.
              * Press the {9} {3} {0} {1} buttons
              on the remote control.
              * The Service Menu will be displayed
              with the following Modes:
              "Options" - "Adjustments" - "Selections"
              * Use the {OK} button to access and
              navigate through these Modes.
              * To change values use {VOL +} {VOL-) {P+} {P-}
              * To exit, press the {MENU} button.
              ***Yet another Different Method*********************************
              enter the main menu by pressing “M” button and then press the digits 4,
              7, 2 and 5 respectively.
              http://www.riddledtv.com/forums/tosh...-lcd-t297.html
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                https://www.youtube.com/watch?v=xDFXYguYCA8
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                • ozy
                  • Jun 2009
                  • 44
                  tried all the above.
                  mute mute meu on tv
                  mute mute mute menu on tv
                  menu 9301
                  menu 4725
                  vol- 9
                  no joy with any...
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    ive just dowmloaded the manual too i cant see the service code either i will upload the manual as maybe usefull for other members
                    • ozy
                      • Jun 2009
                      • 44
                      yea that's the same manual I have, strange why its not mentioned in there........
                      Thx for looking
                      • ozy
                        • Jun 2009
                        • 44
                        while I was trying to access service menu the screen froze and the set shut down, so unplugged it and set had reverted back to its orig fault of no sign of life but 5-12-24v all present at power supply.
                        I resoldered u104 (3.3v reg that supplies dvdd3v3 that pwrs eprom) and replaced c117 (470uf 10v) both capacitance and esr checked ok but changed anyway. Refitted orig eprom (u609) and set now powers up with good picture.
                        will leave it on test and see how it behaves.
                        • Diah
                          • Feb 2013
                          • 6614
                          re soldering u104 was the main fault, orig NVM had its ready written set register and values you are done but remain some side effect, as you need to check and try signal from all sources ... good work
                          • ozy
                            • Jun 2009
                            • 44
                            Well left it on test but this morning its back to the faulty state with no signs of life.
                            • Diah
                              • Feb 2013
                              • 6614
                              its look bad socket or soldering
                              • ozy
                                • Jun 2009
                                • 44
                                no socket its soic direct to pcb, soldering fine wonder if its the scaler ic as that's bga.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  does heating the area of the bga make the tv start?
                                  • ozy
                                    • Jun 2009
                                    • 44
                                    will try that later, the eprom is only about an inch away on the opposite side of the board. going to dump eprom to I think.
                                    • ozy
                                      • Jun 2009
                                      • 44
                                      right I have dumped the eprom (u609) fitted a blank and power led flashing green, removed and refitted orig and reflowed nand and ram chips, set now powers up again and is working, will leave on test and see.
                                      I have attatch dump of the origenal u609 not sure if it is a good dump as set seems buggy but this may or maybe not down to the dump but the set powers up and runs with it.
                                      • ozy
                                        • Jun 2009
                                        • 44
                                        still not working, the fault seems to be occurring more often now, from cold fault there, warmed scaler ic u401 (mt5363efcg) and set powered up.
                                        Removed heatsink and just reflowed the bga chip, resoldered heatsink back and set back on test.
                                        If this don't work I think It will be a scrapper....
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
