Toshiba 50L4353D With 5 Bad Leds !
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    I have this 50" Toshiba Smart Led Tv here and its not a Vestel ! It would turn on but no backlight. Lcd is working fine and can be seen using a torch. Anyway after diagnosing that the Panel (LC500DUE SF R1) had a bad Led inside it I took it apart.
    After doing a bit of testing on the Led strips, I was able to find that this set had 5 bad Leds in total all in different parts of the Led backlight ! There was 4 O/C and 1 that was S/C really odd to me as normally only one needs to pop and they will all go, so I dont know how it ran with this many bad ones because I know they didn't all fail at once.
    Anyway I did the stacking method for repair and used thermal plaster to mount the new stacked Leds, now the set works fine as you can see in the image:
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Toshiba 50L4353D With 5 Bad Leds !
    After repairing any Led backlight I always set the brightness to the lowest I personally feel it can go before the Tv just looks crap. I set it to 15 it orginally was at 100 which is why the Leds burnt up so fast. Anyway working good now and it actually sold before I had repaired it lol
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      nice! I have to do a 55" samsung,led's are in side strip 100 led's on each side. right side bottom 50 don't light up.
      Any tips on handling the lcd panel when you lift it out of the frame? 55" seems wobbly to say the least.
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Cheers Also wow 55" thats going to be fun to do lol, I did this between two beds. I took the Tv apart on my moms double bed and put the Lcd screen after removing it very carefully and rested it on my single bed. It is very fragile and flexible and carrying it was scary as it wobbles about haha.
        The part you need to be most careful in doing is removing it out the frame and then finding a way to pick it up and move it safely IMO. Also with the tabbond driver boards you can use low stick electric tape and fold them over and stick them to the Lcd glass lightly this stops them going all over the place and getting damaged.
        Also is it edge lit the one you have ?
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          yes,edge lit. I would cry if I break the panel.Almost need 3 pairs of hands
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Yeah I have long arms and big hands lol and im quite careful as well so I manage fine. But I would say get someone else to very carefully help you
            Edge lit are also ALOT harder to take apart and replace the Leds but not impossible, you will need a good day or two to get it fixed I would say.
            • flocko
              • Nov 2012
              • 1121
              Use a large sheet of thick brown rapping paper and slide it in under the LCD starting from the opposite end from the tabs. then get someone to help lift using papper like a stretcher to support LCD. have done up to70" LCDs this way
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                Thats a very good idea!
                • flocko
                  • Nov 2012
                  • 1121
                  Yes They do say that ! also wear white cotton type gloves when working on set to stop putting print marks on everything
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    What about a 180" Led Tv Lcd screen ?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Hello flocko,
                      That's what I like with this forum. Some really good ideas.
                      • flocko
                        • Nov 2012
                        • 1121
                        Would not get that in the back of my explorer? and Reecey I dont think it would fit on your Mums bed or through the street door
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Haha
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Nice fix reece, its a pity that the bush edge light ive fixed (bad eeprom) has no option at all to alter backlights level ive just tried in advanced too and no setting to alter it.
                            • flocko
                              • Nov 2012
                              • 1121
                              What power board does it use? If its the s 17IPS20 change the resistor on the LED string driver IC
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Its not a Vestel but UMC and you cant adjust the Bl on them but I dont thk they push them as hard tbh
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Cheers bud Also you might be able to find a way of playing about with the driver to turn down the Bl I would be willing to help if you do. Also they use some cheap Leds in them screens they seem to last longer than Ves or Lg etc strangely.
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    Most String drivers ICs use current-setting resistor just look up data. most run max 200Ma Vestel 17IPS19 + 17IPS20 use the MP3394S four string drivers IC that are also a common problem with them
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Maybe give it a shot Vince as a project ?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Just checked my old thread its a megmeet MP4618 psu these use so not sure what can be done too it this is my thread budm posted a shopjimmy image of both sides of the board in post 9 thanks guys
                                        https://www.badcaps.net/forum/search...archid=6030681
                                        • horus100
                                          Toshiba Z30-A-197 toshiba switched off and 2 blinking leds
                                          by horus100
                                          Hi, I've a problem with my laptop toshiba Z30: do not swith on and thare are 2 blink leds, white and yellow, blinking 2 times each one. I have disconnected the battery, CMOS battery, and reset bios but no effect, the laptop remain still switched off. Do you have any suggestion? Thak you!
                                          12-19-2022, 01:25 AM
                                        • buchman
                                          Toshiba 40L2400VQ No backlight but LEDs are fine
                                          by buchman
                                          I have a Toshiba LED tv model number 40L2400VQ.
                                          I don't receive the correct voltage at the output to the LEDs.
                                          I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
                                          Tested all caps with esr meter and they are fine.
                                          The diodes are fine and the resistors too.
                                          Where should I concentrate on?
                                          Thanks in advance....
                                          03-13-2021, 12:43 PM
                                        • spintop
                                          Toshiba 39P2300VE, faulty backlight LEDs
                                          by spintop
                                          Hi
                                          No backlight issue with the TV.
                                          Opened up panel and found 3 bad leds in the panel.
                                          LED is about 3mm x 3mm, i assume they are the 3030 type. Label on the strip is :AG-D1 94V-O 1345 ( 6 leds in a strip )
                                          Thinking of buying and replacing the individual SMD leds. Found some online, but they have both 3V and 6V. Not sure which one i need, any idea how to tell ?
                                          Thank you....
                                          08-22-2020, 09:43 PM
                                        • ninadpurohit
                                          Toshiba Satelite C850 - No Power, Flashing LEDs
                                          by ninadpurohit
                                          I am trying to fix this DK10FG board for a friend. It is not powering up.
                                          When I plug-in power adapter, its DC IN led and Caps lock start flashing. Even cpu fan gets on/off kick like flashing leds. No battery attached. Nothing happens on pressing power button. I checked the charger IC and it seems fine. (ACOK - 3.3v). Re-programmed the bios but no luck.
                                          I checked SIO chip NPCE885LA0DX and here's the reading
                                          19,46,76,88,115 | P3V3AL_R --> 3.3v
                                          102 | P3V3AL_EC --> 3.3v
                                          4 | P3V3S --> Fluctuates from 0.2v to...
                                          10-06-2021, 11:17 PM
                                        • anlu
                                          Vestel Firmware - Toshiba 32W133DN
                                          by anlu
                                          Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                          Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                          02-04-2023, 12:59 AM
