Samsung PN51D550C1F buzzing sound
  • tech2014
    • Aug 2014
    • 807
    This tv had a shorted X-SUS board. Replaced the board and the TV worked fine. I put the back on and then I turned on the tv. No picture. I took the cover off again. When I powered up the tv, there was a loud buzzing sound which seems to be coming from the Y-SUS. Is this something that can be repaired? What causes the buzzing. Is it possible it is a bad panel since the xsus was shorted out originally.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PN51D550C1F buzzing sound
    These use combined ERC (Ymain and Xmain recovery linked) so if the Xshorts it can damage the Y and the same time. Have you checked the Ymain for short circuits on the Fets ?
    • tech2014
      • Aug 2014
      • 807
      yup, checked the y-main for shorts before replacing the x-main and found no shorts.
        Panel has no cracks?
        • tech2014
          • Aug 2014
          • 807
          Not that I can see.
            09-07-2024, 05:50 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
            09-06-2024, 11:40 PM
