Problem x-board on Samsung PS51E550OD1P
  • Bibu
    • Mar 2016
    • 88
    • Italy
    Re: Problem x-board on Samsung PS51E550OD1P
    I finish the idea with this tv... ...
    I change on the xboard 4 transistors... I checked all the diodes all the resistors, all the caps... And i haven't va and vs.... The problem isn't the power supply, because if i jumper vs with 5v i have the correctly V on the power supply...
    With only the power supply, main board and xboard connected, the va and vs must be present? Or is another board that give the input on vs-on?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      The power supplies in these are load variant meaning if the Sus boards are not connected they wont fire the Vs and Va. You need to check both Y and Xmain for S/C as they are connected together and one can kill the other.
      • Bibu
        • Mar 2016
        • 88
        • Italy
        ok them it's Normal that there isn't vs if y-board aren't connected... At this point there is another problem in y board
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Have you checked the Vs line on the ymain for short circuit to ground like I originally said to do ?
          • Bibu
            • Mar 2016
            • 88
            • Italy
            Sorry if i boring you, but i don't understand what kind of test i must to do...
            With all disconnected on y board red probe in vs pin and black probe on chassis, with dmm in diode mode... Its right?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Not diode-mode, Resistance.
              Tell us the resistance reading....
              TELEFIX
              • Bibu
                • Mar 2016
                • 88
                • Italy
                #27
                Red probe in vs anD black in chassis, i read 17.50 kohms
                • Bibu
                  • Mar 2016
                  • 88
                  • Italy
                  #28
                  Is correct my test?
                  • Bibu
                    • Mar 2016
                    • 88
                    • Italy
                    #29
                    Anyone with other idea for what i must test?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Is that reading on the X or Y board ? Either way seems ok.
                      • Bibu
                        • Mar 2016
                        • 88
                        • Italy
                        #31
                        On y board
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          What about X ? That reading on the Y is normal.
                          • Bibu
                            • Mar 2016
                            • 88
                            • Italy
                            #33
                            On THE xboard, if i check the vs pin Where arrive the cable from the psu i read 196.3 kohms, if i check it on the connector Where i must plugin the second part of the X board, i haven't reading, always out of range
                            • Bibu
                              • Mar 2016
                              • 88
                              • Italy
                              #34
                              Any suggest?
                                09-07-2024, 05:50 AM
                              • howardc64
                                Samsung UN55JU650DF network/streaming problem
                                by howardc64
                                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                07-09-2025, 12:44 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
