Problem x-board on Samsung PS51E550OD1P
  • Bibu
    • Mar 2016
    • 88
    • Italy
    Hi, i have a problem with a Samsung plasma PS51E550OD1P
    The problem is that the X- buffer low board (lj41-10171a) doesn't work correctly, when this board is plugged are present only 5 and 15v, there aren't VA anD VS voltage.
    I just try to test the power board without the x-board ( i make a bridge between vs-on and 5v) and the vs and the va are correct.
    On the xboard i don't see any faulty, all the capacitors and the SMD resistors are good... Where is the problem?
    Sorry for my english please
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Problem x-board on Samsung PS51E550OD1P
    The Ymain gets it power from Xmain on these common issue is Ymain failing but makes the Xmain appear to be at fault as they share the energy recovery circuit.. Unhook the Ymain plug and try to boot also check for S/C between Vs and ground.
    • Bibu
      • Mar 2016
      • 88
      • Italy
      Thanks for reply, but if i connect the xmain, the vs voltage must be present? Because i just try with only x-board connect, and i can see only 5 and 15v
      • Bibu
        • Mar 2016
        • 88
        • Italy
        Anyone that can help me please?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Right does your DMM have a diode mode ? Also do you know how to check for S/C ?
          • Bibu
            • Mar 2016
            • 88
            • Italy
            Yes i can do it... But i must do it in x-main board?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Right unplug the Ymain from Xmain and unplug Xmain from Psu. Then if you look at the connector you can see something like "Vs" put your meter in diode mode then black probe to chassis ground then red probe to "Vs" on the Xmain what do you get ?
              • Bibu
                • Mar 2016
                • 88
                • Italy
                Ok, with all unplugged, in the vs ( there are 2 vs pin in the same connector), i have 0 and beep
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Vs on the Xmain or Ymain either way thats a dead short to ground on the Vs input which is not good ?
                  • Bibu
                    • Mar 2016
                    • 88
                    • Italy
                    probably...but this could be caused by what ? the board of the tracks are in good condition ... it could be a mofset or resistance ?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Shorted transistor, they are mounted under the pcb. Remove it and test them for S/C.
                      • Bibu
                        • Mar 2016
                        • 88
                        • Italy
                        Where i can see the chassis number of this tv? I don't find any service manual with product number
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Service-manual will be utterly useless anyway--No schematics are ever included for Samsung sets--like most of em these days. Firelighter fodder only.
                          --If Y is bad, all the service-manual will say is replace it!
                          --Pointless rubbish--not a service-manual, its a joke!
                          TELEFIX
                          • tech2014
                            • Aug 2014
                            • 807
                            I agree 100%, I don't even bother wasting my time downloading SM anymore.
                            • Bibu
                              • Mar 2016
                              • 88
                              • Italy
                              and without datasheet as you do ? You will make tests at random ?
                              • Bibu
                                • Mar 2016
                                • 88
                                • Italy
                                There is anyone that can help me to test this transistor FGD4536TM with a dmm?
                                • Nick's Tvs
                                  • Jan 2014
                                  • 621
                                  Take it out of circuit, go to ohms and test every leg in every direction. You should always read O.L on your meter in every direction except for 1 where you will read anywhere between 5 mega ohms to 15 mega ohms. When I say test every leg in every direction, I mean red on drain black on source, and then black on drain, red on source. Then red on drain black on gate, and same thing black on drain, red on gate. Finally red on gate, black on source and then black on gate red on source. Doesn't matter if you know which leg is which, as long as you don't get readings in the K ohms.
                                  • Bibu
                                    • Mar 2016
                                    • 88
                                    • Italy
                                    Hi nick thanks for help.
                                    My problem is that there isn't drain gate anD source, but there are gate emitter and collector... Are the same with differen't names?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Its the same way to test them though.
                                      • Bibu
                                        • Mar 2016
                                        • 88
                                        • Italy
                                        Thanks i found the transistor shorted
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
