Samsung LN46D550K1FXZA No Image
  • eagle00799
    • May 2012
    • 322
    I have sound and backlights but no image so I replaced the t-con board from ShopJimmy but the problem is the same. All voltages are checking out good, 13v,5v and 3.3v are there and the 12 volts on the t-con board is there. I have heard Samsung had some bad panels but I can't imagine it just stops working. When I power the tv on the red power light will flash 5 times then I can see a flash in the lower right of the screen, backlights will come on and sound will come on but no images. Unfortunately I do not have the remote for this tv.
    Re: Samsung LN46D550K1FXZA No Image
    What happen if you have the ribbon cables between the LCD panel and the T-CON board connected one at a time?
    • eagle00799
      • May 2012
      • 322
      No change at all
        Nest thing to do is to verify if the main board is sending the signals through the LVDS cables to the T-CON or not but you will need the scope to do that.
        • eagle00799
          • May 2012
          • 322
          Budm, i replaced the main board as well with one from shopjimmy and no change.
          • eagle00799
            • May 2012
            • 322
            Maybe i should test the cable itself.
            • eagle00799
              • May 2012
              • 322
              On the P_DIM I get 2.05v , is that sufficient voltage?
              • Diah
                • Feb 2013
                • 6363
                go down to the LCD and there are DUMY left and right side they are Fuse, check them and post here
                • eagle00799
                  • May 2012
                  • 322
                  I don't see any fuse on those boards,
                    That is the Backlights dimming control signal.
                    I doubt that you will find SMD fuses of those tab bonding boards, it is not one of those LCD panel with integrated T-CON panel type.
                    • Diah
                      • Feb 2013
                      • 6363
                      picture 1 on the top right over the hole !!! ist DUMMY?
                        09-07-2024, 05:50 AM
                      • max789
                        Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                        by max789
                        Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                        I made the following tests:
                        1. Disconnected the main board from Power Board = backlight works.
                        2. Connected the main board and disconnected the T-Con = backlights does not work.
                        So I ordered a main board from Ebay also BN41-02156A but from...
                        01-18-2024, 06:56 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
