Samsung LE26R81B - BN44-0156A fault
  • angel-boy
    • 550
    source Samsung BN44-0156A make a noise , only power led on, not starting.
    - i tested with another sourse and works great.
    13v - i have 2v
    , 24v - i have 3.3v
    5.3v - i have 1.7v
    where to look ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Samsung LE26R81B - BN44-0156A fault
    What DCV do you get when you measure right at the main filter capacitor on the primary? Check the power supply for cold solder joints around the transformer.
    • kep58
      • Jan 2016
      • Ukraine
      Bn44-00156a
      bn44-00156a = bn44-192a
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
        09-07-2024, 05:50 AM
      • K212
        Samsung QE65Q700TATXXC is not starting
        by K212
        my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
        The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
        I contacted Samsung support who said it is most...
        07-31-2025, 12:45 PM
        09-06-2024, 11:40 PM
