Samsung HPT5044X/XAA plasma keeps blowing buffer ICs
  • mattpd
    • Oct 2012
    • 301
    This one started with no picture but had sound, protection light lit on YSUS. Found the blown buffer IC and replaced it. I also used a eBay repair kit on the YSUS which replaced all the blown FETs and more.
    Plugged it in and the screen lights up, but with garbage on screen. About 15 seconds later one of the IC on the top buffer board blows and YSUS protection comes on again.
    Replaced blown buffer IC then check YSUS. Nothing is shorted this time. Installed both and turn on TV. Garbage on screen, 15 seconds later a different buffer IC blows.
    Repeated this a few more times and now I have gone through 5 ICs already. Three of them on top board and two on bottom board. I am guessing that YSUS is malfunctioning in some way, but it's not the same failure that it had originally.
    Any idea?
  • RCA2000
    • Sep 2014
    • 111
    Re: Samsung HPT5044X/XAA plasma keeps blowing buffer ICs
    Hate to say this...but repeated blowing of Y buffers..particularly the SAME One..often means a bad PANEL.
    • mattpd
      • Oct 2012
      • 301
      Different IC every time. Still think bad panel?
      • libyantiger
        • Dec 2010
        got samsung plasma tv from recylce bin ...the panel have miniature crack!!
        i was hoping i can fix it
        trouble shooting reveals that the problem is in the y-buffer ...the y board tests ok
        ...looks like the fate is with me ...with an incredible luck i find yet another plasma in recycle bin and of an identical model
        i find all boards has been stolen by another tech (maybe) but the y-buffer is there
        i quickly got the y buffer ...the problem that it was full of dust dirt and tiny rust
        i started cleaning it with thinner solution and brushing it with tooth brush to cleanse all the rust and dust away
        after the job is done i installed the buffer in tv and i fired up the tv ....and guess what??
        the tv worked!! the picture is there ...but it is not perfect...it sort of "double image " problem
        with the word "no signal" appears twice ...
        i tried to reset the ribbons ...while the tv is off and when i refire the tv ....it is nothing
        i tested and find the buffer got shorted again
        from your experience
        could the buffer be shorted because of the fact that it has poor connection to the ribbons due to rust
        or the bad panel (because of the small crack)is loading down the buffer "but the picture appeared ...smeared yes
        ...but it was there "
        • Yanleb
          Schematic or datasheet for Plasma TV buffer chip
          by Yanleb
          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
          05-18-2022, 01:36 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • legg
          LG 42PC3 buffer output doesn't follow YSUS
          by legg
          LG42PC3D -UD originally with green lamp but no display or audio.
          Owner says was working, then went 'pop'.
          All 5V caps bulging. replaced.
          All PSU output voltages within spec but -Vy is low on YSUS.
          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
          eventually shorts DG. Replaced all 3 - -Vy now OK.
          Y scan buffer test point does not follow YSUS output below -50V
          Note: This unit seems to expect YSUS output to park at -Vy in between
          drive signal pattern periods. A replacement drive signal board confirms this....
          11-18-2021, 11:49 AM
        • Bad_Boards
          LG Plasma TV Bad Y Buffer Replacement
          by Bad_Boards
          Background:
          I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
          Question:
          Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
          Could I somehow check the Y-Sustain board to see if there was any damage done to it?
          04-07-2021, 09:39 PM
