VESTEL FIRMWARE: Toshiba 32W1333B
  • nono_sax
    • Jan 2025
    • France
    #61
    I just got a 17MB95M card from a Medion TV (MD30814)
    I would like to put this card on my Toshiba television (48L5435), but I cannot put the Toshiba firmware on this "Medion" card
    first of all, do you think this is possible?
    my tests:
    USB format: FAT/FAT32
    Medion firmware/Toshiba firmware
    I manage to trigger the update by typing Menu->1505, but it gets me every time: "Software update failed"
    the firmware I found for my Toshiba only contains one file (spi-vistel-17mb95m-48l5435dg-.bin); is this normal?
    I tried yours (the 3 files) to see, and I always marked Failed
    Thank you in advance for your answers!
    Christian​
    • lotas
      • Jan 2016
      • 4862
      • Russia
      #62
      Originally posted by nono_sax
      bonjour à tous,
      je viens de récupérer une carte 17MB95M provenant d'un téléviseur Medion (MD30814)
      je voudrais mettre cette carte sur mon téléviseurToshiba (48L5435), mais je n'arrive pas à mettre le firmware Toshiba sur cette carte "Medion"
      d'abord, cela est-il possible d'après-vous ?
      mes essais:
      format USB: FAT/FAT32
      firmware Medion/firmware Toshiba
      j'arrive à déclencher la mise à jour en tapant Menu->1505, mais ça me marque à chaque fois: "Software update failed"
      le firmware que j'ai trouvé pour mon Toshiba ne contient qu'un fichier (spi-vistel-17mb95m-48l5435dg-.bin); est-ce normal ?
      j'ai essayé le votre (les 3 fichiers) pour voir, et j'ai toujours marqué Failed
      merci par avance de vos réponses !
      Christian
      "spi-vistel-17mb95m-48l5435dg-.bin" is the firmware (dump) through the programmer for spi flash MX25L1606E.​
      PS. Write in English language.
      • anlu
        Vestel Firmware - Toshiba 32W133DN
        by anlu
        Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
        Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
        02-04-2023, 12:59 AM
      • lberkani
        Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
        by lberkani
        I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
        The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
        The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
        I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
        - Toshiba 65UL2163DG
        - Vestel 17MB180E mainboard
        - Panel VES650QNTX-N2-N42
        - Version V1.28.100.0 if available
        If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
        11-11-2025, 12:37 PM
      • cheeky2
        Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
        by cheeky2
        I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
        Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
        The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
        Details:...
        08-17-2023, 04:34 AM
      • Bazilwrc164
        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
        by Bazilwrc164
        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
        If anyone can provide:
        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
        • Or a compatible EEPROM dump
        07-23-2025, 12:15 PM
      • DarrenHD
        Firmware for older Toshiba TV 22CV100U
        by DarrenHD
        HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
        I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
        https://support.dynabook.com/support...tentId=2865076
        Thanks!
        06-16-2025, 11:56 AM
