LG32LN4500 No Display, but Audio work
+ More Options
Posts
  • kazia
    • May 2015
    • 145
    • indonesia
    LG32LN4500 No Display, but Audio/sound work
    TV powers on, Audio there, no pic or backlight.
    got schematic for LGP32-13PL1 it's same power schematic at page 19.
    measuring at P201
    power on = 3v
    drv on = 2.9v
    PDIM = 1.1V
    3.5V, 12V, 24V ALL good.
    measuring at IC801
    1. 2.3V 8. 5V
    2. 12V 9. 0V
    3. 0V 10. 2.2V
    4. 0V 11. 1V
    5. 0V 12. 0V
    6. 3V 13. 0.6V
    7. 0V 14. 0V
    Problem with IC 801 or what...
    thanks
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: LG32LN4500 No Display, but Audio work
    any one...
    • kazia
      • May 2015
      • 145
      • indonesia
      update, change the ic 801, still same problem.
      • RCA2000
        • Sep 2014
        • 111
        LIKELY...you have one or more LED strips in the panel...with at LEAST one bad LED. On P-801..pin 1 and 7 See if at power on, maybe after a few seconds...You get a BURST..of at least 100-170V...at least for a few seconds. If it DOES...then drops after that...it is VERY likely an LED BL problem. Remember these are run in SERIES>..and if ONE opens....AL on that string go out. And if the sense ckt. detects an abnormal draw..OUT it goes...
        We are seeing a WHOLE LOT of LED BL problems... they are FAR..FAR LESS reliable...than claimed.. It has been claimed here it is because they are NOT really using them correctly, overdriving them...not sinking them enough, etc. LIKELY TRUE
        Just MORE evidence..that the 'ol CRT...will NEVER be even EQUALED...let alone surpassed..as a display device...as far as reliablilty, simplicity and longevity goes. PDP..DLP...LCOS..DILA...ALL have pretty much "had their shot" and FAILED.to do so...
          Page 9 of the provided power supply SCH:
          LED B+ 65.6V~86.9V 0.4A(0.380~0.420A) ± 5% -
          So what do you get on the L+ pin of the LED connector, 33VDC?
          33VDC (DD) is the feeding Voltage to the Boost converter to boost the Voltage up to around 90V for the LED strings.
          • kazia
            • May 2015
            • 145
            • indonesia
            thanks for reply, on LED B+ it's fluctuation 10 - 18v.
            my be it's something shorted inside lcd.
              Disconnect the LED connector first and check the L+, if the booster circuit is not working then you will only see the feeding Voltage which will be 33V, you have to have that 33V at least, look at the diagram on where the 33V is generated from.
              It is generated by the same power transformer (T101) that also generates the 24V and the 3.5V supplies.
              You need to check that 33VDC (DD) source to see what you have.
              • kazia
                • May 2015
                • 145
                • indonesia
                disconnect the connector, got same situation, measuring (LED B+ and LED -) its still fluctuation about 10 to 18v.
                on caps 801 or LB801 a little fluctuation about 120 to 125v
                • RCA2000
                  • Sep 2014
                  • 111
                  No... check the + connector to GROUND...and see what you get THEN.,
                  • kazia
                    • May 2015
                    • 145
                    • indonesia
                    + connector to ground is same as c801 to ground fluctuation about 120 to 125v,
                    then what should I check next.
                      OK, so you were not using Gnd as the ref for your meter, since you are see over 100V that means the boost converter is working and you have open circuit in the LED strings.
                      • RCA2000
                        • Sep 2014
                        • 111
                        You need to "force on " the Backlights now. YOU will need a resistor of say 220 ohms or so. Take one end--connect it to ground. The other end connect it to other LED - pin of that connector Power up and watch for that resistor to get HOT fast--BUT if the BL is ok...it should light DO NOT...do this for more than a few seconds...just long enough to PROVE the BL.
                        • kazia
                          • May 2015
                          • 145
                          • indonesia
                          confirm again, R220ohm connect to ground and LED (-) pin.
                          how about the connector should I connect it to.
                          • kazia
                            • May 2015
                            • 145
                            • indonesia
                            done, places 390 ohm resistor, the screen still dark, but it flashes after disconnected power cord.
                            and resistor not get hot.
                            • samson7point1@yahoo.com
                              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                              by samson7point1@yahoo.com
                              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                              The player processes the audio signal using two different reference frequencies. The "R"...
                              04-30-2024, 11:22 AM
                              DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                              This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                              09-06-2024, 03:21 PM
                              09-06-2024, 08:44 AM
                              Lenovo IdeaPad 3 Notebook Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad 3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 boardview and 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 3 Notebook...
                              09-07-2024, 04:30 AM
                              Lenovo IdeaPad C340 Hybrid (2-in-1) C Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad C340 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C340 boardview and C340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad...
                              09-06-2024, 12:30 PM
