Samsung Tuner issue
  • Twithers
    • May 2013
    • 69
    • U. S.
    Samsung Tuner issue
    I have a Samsung LN46A530 that I picked up and replaced a T-con board in. Everything is working perfectly except for one strange issue. After doing an autoprogram for the DTV or over the air channels, which pulled in all the available channels, whenever I select a channel, the signal cuts in and out. It's not entirely random, but not at exact intervals either. Pulling up the signal strength meter, you can watch it stay at full bars for a few seconds and then drop enough to cause blocking in the picture or even drop to zero bars causing the black screen with the "Weak or no signal" box.
    I have gone into the factory manual and the tuner is set to Semco, which I believe is correct (I have tried Alps in the past and it picked up no channels when programming), but I can't find anything else to effect the tuner operation.
    The antenna setup is exactly the same as it was on the Olevia I was using before this one.
    I have tried various amplifier configurations to see if that would help, but with no luck.
    It is pretty un-nerving to watch any channel.
    Any ideas?
    On a side note: when going in to the factory menu under the option byte, how do you know which screen to select, i.e. 46 L C, 46 D HC, etc.? There are several for the 46" screen. I have cycled through them with only very minimal differences.
    Thanks.
  • Twithers
    • May 2013
    • 69
    • U. S.
    Re: Samsung Tuner issue
    After reading some similar posts, I had some othjer info to try and narrow down the possible issue.
    -The tuner does actually function and it acquires all the channels I would expect and even some low gain channels that I hadn't previously pulled in with other tv's.
    -Some channels stay at full signal strength longer than others before dipping a few bars or dropping completely, but all the channels do it at some point.
    -I left it on all night to see if it was a heat versus cold start issue with no observable change.
    -I saw a couple posts mention updating the firmware, which I tried but I guess since I already have the latest version installed, it won't load. Is there a way to reflash the same firmware or should I try an older firmware, and if so, how would I make it load that.
    That's all I can think of for now.
    Thanks.
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
    • vincentedel
      Samsung SyncMaster 740n Phase Control Issue
      by vincentedel
      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
      04-22-2025, 12:33 AM
    • Manucsl
      QE65Q800TATXXC Samsung TV Issue
      by Manucsl
      Hello.
      My TV is a QE65Q800TATXXC Samsung TV.
      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
      Any ideas to check would be very appreciated 😊
      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
      02-19-2025, 07:47 AM
