50PFP5532D/05 Very Poor Image Help ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello all, I have this Phillips 50" Plasma its a rebaged Samsung PS50Q97HD etc. There were two shorted devices on the Ymain, after replacing them the Tv turns on and give image but its crap lots of MD and other issues.
    I have set all the Sus voltages to what I person know these Panels run fine at but this one still looks poor as heck, any ideas could my Xmain be at fault ? Im stuck on this and can not sell it like this, I cant get it to even look slightly decent either.
    Link to video of the Tv and fault:
    https://m.youtube.com/watch?v=Ysk8Vnsbz4I
  • sordids999
    • May 2013
    • 2161
    Re: 50PFP5532D/05 Very Poor Image Help ?
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Wow lol, I have a video is that any good ? Haha
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Boost still cant solve this. Got to be a sustain drive fault as the Panel cant be that tired but everything checks fine
          Looks like a worn out panel - same cause as LG maldischarge. AFAIK Samsung never released a firmware update but it was fixed in later panel revisions, so if you can find a control board from a newer set that may work. If the hour count doesn't line up it may cause the same problem so you may have to transplant the EEPROM between the boards.
          Long and short, not really an easy fix.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Thanks Tom, this is a cluster fuck of a Tv it doesnt even improve after warm up Maybe if I got a new epprom for cntrl as I know they are sold separately ?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              You think thats possible to order a brand new epprom setup for this board ?
                No, the EEPROM doesn't store the firmware, flash memory does. A blank EEPROM would likely cause the controller to get very confused about everything and in a moment of spite it may just decide to blow the Y, X and panel all at once. (It's possible to write firmware that can do this )
                EEPROM and flash memory are different devices. I'm sure I keep mentioning this and no one seems to listen...
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Yeah I just get confused between them still learning buddy Ohh well will see what I can do for this POS lol
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ordered Cntrl board as image will not clear even after being on for hours and properly warm, peoples faces and other colors are way off. Will keep you updated.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok I decided to run the set for a few hours while I went out, still same crappy image when I left now im home the screen is almost fully white. Still on freeview have sound and I can very faintly see the image in the back ground, the contrast and colour are at the normal setting and I can still adjust them. I switched it off for a few hours but still same issue, faded out full white screen
                      Any ideas ?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ok so after turning it back on again its now back to the original crappy MD image wtf ? All voltages bave been adjusted to whats has been recommended on other threads, at factory panel voltages it looks 100% worse.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Something is not right with this, I was running it fine with the crappy MD image then all of a sudden the screen went full white again and faded out. I dont think thats a panel issue ?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Well I found the fault ! After heating the control board the fault occured stright away I suspecting the caps on it are bad, so I will remove and esr them. Knew this was not a panel fault, hopefully if I replace/repair it the MD will go
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Found that almost every 220uf 16v Smd cap had failed. Worst having 14 ohms across it ! However replacing them did not fix the issue. So ordered a control board to see if it will fix it. Will keep you updated.
                              Image showing the caps replaced, yes I used Rad type caps as I do not stock SMT type.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Call me an ass wipe eveyone ! The Ymain was the issue and I just fixed it anyone guess the fault ?
                                If you cant well it was a blown fuse lol F5200 which provides power the the Long Yset area was O/C after changing it the image is now awesome and the cntrl board when heated no longer messes up. I was able to determine the Ymain was the fault as I have another from a C96Hd and putting that one in made the Tv work great.
                                So after checking around found that fuse to be blown probably happened when the fet shorted originally lol. The display now looks great, not a single lick of MD at all which is awesome
                                Thanks for the input chaps.
                                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:20 PM
                                • Jaime Morillo
                                  Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                  by Jaime Morillo
                                  Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                  The TV was stuck on the logo and I couldn't access the update menu.
                                  I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                  The image result was good, but the image is inverted.
                                  The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                  Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                  08-18-2025, 11:38 AM
                                  HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-06-2024, 10:56 AM
                                  HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                  HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
