Sony Bravia KDL-42V4100 washed out image
  • braxton
    • Nov 2009
    • 146
    I just picked up a 2008? Sony Bravia that powers on with a green light and no errors but the picture is very dull and dark. Reset does not help. The video appears to be fine with no lines or ghosting but it is very dark and dull. Backlights are bright and working well. The image is the same regardless of input and even with no input the menus are also very dark. I've attached a picture.
    Is the most likely culprit a bad main video controller board?
    https://www.dropbox.com/s/ei9ton02lu...ravia.jpg?dl=0
  • braxton
    • Nov 2009
    • 146
    Re: Sony Bravia KDL-42V4100 washed out image
    trying attachment again...
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Check gamma voltages around AS-15, as this is a common cause of this problem
      TELEFIX
      • citywidetvtech
        • Jun 2014
        • 14
        Have you unplugged the IR/Photo sensor after turning it on to make sure it hasn't failed. I had a few do this and needlessly ordered main boards to fix them.
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
