Samsung UN40C5000 identify LVDS cable replacment
  • mpadilla
    • Dec 2015
    • 24
    • US
    So now that my friends found out that I'm fixing tvs for my family's use they're all giving me their non-working ones sitting in their garages. Picked up this Samsung UN40C5000. It powers on with a picture on the left side but the right side is black. After reading the troubleshooting guides I moved the LVDS cable and it brought back one fourth of the blackness to vertical colored lines. Based on what I read, if ANY change occurs, then the problem is the cable. But I also read and saw pictures in the troubleshooting guide that says if you have colored vertical lines it could be the TCON board or the main board IC. Previous owner says the TCON board was replaced prior to giving it to me but they didn't want to pursue paying for it to get fixed any more. So I want to buy an LVDS cable and then go from there. If the new cable gives me back the full right side with colored vertical lines, then I assume I then need to replace the IC. At least I'm hoping that's how it goes. Pulled out the LVDS cable and the number is BN96-13171G. I cannot find a replacement anywhere. The stamp on cable says AWM 020706 105C VW-1 HF -F-. I couldn't find in any of the guides on how to identify a generic replacement cable. Also, cannot locate a service manual ANYWHERE. I have a request in at eserviceinfo for it. So my question is how do I identify a generic replacement to purchase?
    Any guidance would be appreciated as I feel I have exhausted all my resources.
    Thank you so much!
  • mpadilla
    • Dec 2015
    • 24
    • US
    Re: Samsung UN40C5000 identify LVDS cable replacment
    Sorry folks haven't been around in a while as my spouse had brain surgery. Consider this one closed. At the time when i posted I was unable to locate the cable. I have had luck since then and it's on its way. Thank you again for all the help you provide!
    • mpadilla
      • Dec 2015
      • 24
      • US
      Ok so I've identified the basic cause of the problem. Wasn't the LVDS cable. It was what's pictured. The last tab on the right when applying slight pressure changes the vertical lines. I don't know what it's called or the part number...YET. Just wanted to give an update that I got a little further.
      • mpadilla
        • Dec 2015
        • 24
        • US
        Aaaaand looks like I found the repair
        https://www.badcaps.net/forum/showpo...20&postcount=1
          09-07-2024, 05:50 AM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
