Samsung BN44-00441A ceramic disk failure.
  • Shinju
    • Mar 2014
    • 1239
    Hey all!
    Took a long break from repair hobby and decided to jump back in a little bit.
    Anyway I got a 46" Samsung power supply BN44-00441A that suffered from a catastrophic failure near the secondary relay it looked to be a green ceramic disk that had failed so bad the board was scorched and the disk cracked due to excessive heat or able to get a full part number from it.
    Anyway I had a Sony power supply out of another LCD tv that had a similar ceramic green disk near its turn on relay so I densolidered it and after some patch work was able to mount it to the Samsung power supply.
    I re installed the Samsung power supply and the panel fires right up no issues.
    My question is what exactly is this green ceramic disk and is the one I put in from the Sony SMPS work for the Samsung SMPS long term?
    Should I replace it with a new part that was per spec for the BN44-00441A?
    Photos attached.
    Thanks in advance!
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung BN44-00441A ceramic disk failure.
    Part I harvested off the Sony SMPS photo attached.
      Thermistor for inrush current limiting, if it blew that means you may have shorted circuit or the part was damaged?
      What is that part designator as printed on the board? TH?????, NTC???
      Do you have the P/N of the sub you installed? SCK105 (10mm Dia 5 Ohms cold? or 10 Ohms 5A?)? Same 15mm DIA as the original? I see WMEC,15D030?
      https://cdn.badcaps-static.com/pdfs/...ed0b900dce.pdf
      You can check the Voltage drops on that Thermistor and the temperature to see if it is getting too hot.
      • Shinju
        • Mar 2014
        • 1239
        Hey Budm
        Thank you for clearing that up for me, Thermiser!
        Anyway looks like the board code is NT801S. The part I used seems to get pretty warm to the touch I have not taken voltage yet. What should I be looking for voltage wise?
        I chiseled away as much carbon as I could, excuse the dirty solider work. this was just to make sure the panel was in working condition before investing any money into it.
          Originally posted by Shinju
          Hey Budm
          You need to take the resistance of that Thermistor to get the room temperature resistance, then power up the TV for 10 minutes or so and then take the ACV reading between the two legs of the Thermistor to calculate how much power it is dissipating. So can you read the print on the old one and check the Diameter? Is it 15D030?
          • Shinju
            • Mar 2014
            • 1239
            Go it, will report back when I do.
            Yes the old part was a 15D030, the new parts diameter is a little smaller then the 15D but it's also a tad thicker to the eye.
            Thank you for the input so far!
              I look at the diagram of Samsung_BN44-00428B and I see the same brand of Thermistor
              WTR 15D050 (for 5 Ohms), your board uses WTR 15D030 which is 3 Ohms, 15mm Dia. You have to use the Dia. for it to handle the power.
              • Shinju
                • Mar 2014
                • 1239
                ACV 1.280 fluctuating
                Resistance 1.8-1.6
                  Did you let it cool down first before making the resistance reading? I expect it to be about 5 Ohms cold.
                  But anyway, your original one is rated at 3 Ohms, 15mm Dia.
                  • Shinju
                    • Mar 2014
                    • 1239
                    I took resistance before it was powered up after sitting all night. I think I need to charge my fluke when set to ACV and sitting with the probes touching noting I see the read out showing voltage readings on the display.
                    Either way looks like I need to order the correct thermistor anyway, what would cause that to fail anyway? Leaving the panel on 24/7?
                    After closer inspection of the panel it looks like it has burn in, a perfect rectangular pattern covering the screen leaving about an inch of clear screen from that to the bezel. Only really noticeable on solid bright colors white/green ect.
                    Thank you Budm for your help!
                    • Shinju
                      • Mar 2014
                      • 1239
                      So I was running color test on my test disk but in the service menu I only see the burn in outline on grey.
                      All other colors look fine. Panel has 13k hours recorded.
                      • Shinju
                        • Mar 2014
                        • 1239
                        Clean logic patterns
                        • Shinju
                          • Mar 2014
                          • 1239
                          Clean logic pattern 2
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4959
                            • New Zealand
                            Could do, if it got really hot maybe.
                            Normally they blow when something else blows, like budm already said.
                            But since the rest seems to work, I guess it's just old age failure of the thermistor, or it was damaged during production or other repair etc.
                            -David VanHorn
                            • Shinju
                              • Mar 2014
                              • 1239
                              For shits and giggles I decided to leave it on for a hour or so with a movie playing so it would draw maximum current to see if it would fail or the smaller thermistor would get excessively hot.
                              After a hour or more I turned t off and touched the Thermistor with the tip of my finger it was hot but not like Woah burn the finger tip hot, I was able to hold my finger on it.
                                Just keep an eye on it then for your own use, but I would get the original spec if it belongs to the customer.
                                  09-07-2024, 05:50 AM
                                • DynaxSC
                                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                  by DynaxSC
                                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                  The behaviour is also really very strange, i.e.:
                                  • The disk shows always up in BIOS - so it is recognized, so far so good
                                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                  02-23-2025, 01:33 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
