Sanyo DP32628 display turns off
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Sanyo DP32628 display turns off
ok i just did it. for some reason the display/backlight kicked off really soon this time so i couldn't catch it early, but right now the volts at the STB terminal reads 3.2. I think I heard a really faint squeak too.Comment
OK, so backlights ON command stays on, but how about the 24vdc?Never stop learning
I didn't catch this part. Where is this 24vdc that i need to test? I assume this on the yellow board but I can't tell what I need to be looking at over there. there's 2 chips and to the right it says
5v
12v
24vLast edited by hairywbush; 12-29-2015, 04:56 AM.Comment
Look at the inverter board connector.Never stop learning
I see what you're talking about now. it's on the other end of the connector, coming from the main board. Alright it's a 10 pin connector. 1-5 24.2/3v & 6-10 GND. That checks out! I don't see an issue there.Comment
How about the STB (BL-ON backluights ON) signal? It should be <1Vdc when TV is OFF, and more than 2.5VDC when backlights are ON.
ADJ pin =???vdc
STB = ????VDC
What is the '1-5 24.2/3v & 6-10'Last edited by budm; 12-29-2015, 04:56 PM.Never stop learning
the STB on was 3.2. I just had it off and it was 0.0. iit's been off since my last post if that makes a difference..but I turned it on to check again and now the tvs backlight is staying on. I'm at about 2 mins with it on At the moment. I haven't messed with anything and it's all still connected.Last edited by hairywbush; 12-29-2015, 05:02 PM.Comment
If the 24VDC and the STB are present but the backlights go off, then we know it is not power supply or main board problem, that is why we need to narrow first, if those two are present then it can be either bad inverter board or bad lamp/s.
Never mind, your inverter board does not have fingers for the lamp sockets.
Those four electrolytics caps should have the capacitance and the ESR tested to make sure they are OK.Last edited by budm; 12-29-2015, 05:10 PM.Never stop learning
you mean the bulb connections? I'll wipe them like you say. can I use dielectric grease on them or anywhere on this board?Comment
So the backlights are still staying on?Never stop learning
they unfortunately are turning off again. it was on for a good 10-15 mins. wasn't paying too much attention at how long.Comment
I do not expect bad inverter board to stay on that long but I can be wrong, but the lamps can go bad after they are heated up to the running temperature.Never stop learning
Yo may have poor connections on the lamps sockets, you need to open up the panel to inspect the lamps and the sockets.
And just to be sure, you still need to test the capacitance/ESR of those 4 caps, as temperature goes up, the ESR will go down may make the circuit operate little better.Last edited by budm; 12-29-2015, 06:05 PM.Never stop learning
which caps are you referring to? and do I need some tool to test esr?
i'm about to try and open up the back of the screen. anything I should be careful of? I see screws hold it from the perimeter.Comment
There are 4 electrolytics caps laying on its side on the inverter board, you need capacitor tester that can do the ESR testing, or cheaper way will be replacing them with low ESR type caps not general purpose caps and see what happen.Never stop learning
hey bud, I took the screen apart (it was actually only 10 screws) and here's what i found. that one is clearly burnt. the other marks you see in the other pics is just in the plastic so maybe they're ok?
edit: I took off the platic that covers them. easily at least 2 burnt.Last edited by hairywbush; 12-29-2015, 06:57 PM.Comment
You found the problem. It looks like it has high contact resistance between the end of the lamp and the socket so it heats up and cause more bad contacts, or the lamp is badly worn out an the end of the lamp turns red hot. See pix of what bad lamps will do to the wires.
You also need to look at the end of the lamps to see if they lots lots of blackened ends which will mean worn out lamps, you will have to remove that white plastic to see the ends of the lamps.
Pix of bad lamps:
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Aspire Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) boardview and Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office...09-07-2024, 01:00 AM
- Loading...
