AS15-F Tcon Chip
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    AS15-F Tcon Chip
    I have a Tcon board with an AS15-G chip which I believe to be faulty. Have a solarized screen. I believe I can replace it with an AS15-F which I have available but would like confirmation before I go ahead.
    Regards
  • diif
    • Feb 2014
    • 6978
    • England
    Re: AS15-F Tcon Chip
    Yes, it's fine. I don't know if you've done one before, but be careful not to give it to much heat when soldering on the chip, I've found them quite sensitive to heat.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Many thanks for your reply.I'll be careful.
      Regards
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
