Orion 32" LCD
  • mikay786
    • Aug 2014
    • 765
    Orion 32" LCD
    Got this LCD which powers up from standbye, power indicator turns to green but get no picture and no backlight. Once powered up cant turn it off either.
    Ive found a 1.6a 125v fuse that is blown near the top middle heatsink. Ive tested the 3 transistors around it which all check out.
    I'm struggling a bit testing this schotty barrier diode attached to the heatsink(as not done before)
    yg862c10
    It is only reading one way in diode mode but only reading 0.233v
    Black probe in on middle pin and red to either side L / R pins 0.233v
    From other diodes I have tested its usually between 4 and 6 is good, but not sure if this 0.233v with this particular type of diode is low.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Orion 32" LCD
    this is the data sheet if you need it
    http://www.datasheet4u.com/datasheet....php?id=768112
    im not sure how to read the data sheets myself really if a more experienced member can take the time to explane which figure we should be looking at on the data sheet im sure that would help a few members
    • mikay786
      • Aug 2014
      • 765
      Re: Orion 32" LCD
      Thanks, not really sure if it tells anything with measuring out of circuit
      • vinceroger69
        • Mar 2012
        • 6714
        Re: Orion 32" LCD
        can you upload a picture of the bottom of the board that the fuse has blown on thanks
        • mikay786
          • Aug 2014
          • 765
          Re: Orion 32" LCD
          yep one sec
          • mikay786
            • Aug 2014
            • 765
            Re: Orion 32" LCD
            What I have found is another identical diode further down, so can measure that to see how they compare.
            • mikay786
              • Aug 2014
              • 765
              Re: Orion 32" LCD
              Yea they both measure the same so probably good
              • mikay786
                • Aug 2014
                • 765
                Re: Orion 32" LCD
                cant see anything else around that could have blown the fuse, little diode uptop is good too.
                Worth replacing fuse and just testing?
                • mikay786
                  • Aug 2014
                  • 765
                  Re: Orion 32" LCD
                  Looks like it was just the fuse
                  Ive just used a regular 1.6a 250v Quick Blow glass cartridge fuse (Soldered some legs to it)
                  The specs on the board are 1.6a 125v (not sure if quick / slow / delay) etc
                  Its seems to be working fine, is that alright as a long term solution?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Re: Orion 32" LCD
                    glad a new fuse fixed it leave it on test a while turning it on and off a few times, if alls ok and i was selling the set i would replace for the correct type of fuse, maybe a more experienced member will help find a link for some im not sure what that type of fuse is fast/slow blow etc.
                    • mikay786
                      • Aug 2014
                      • 765
                      Re: Orion 32" LCD
                      Yea it's not something I'm gonna keep, got it for free with intentions fixing / selling on.
                      I'll use it for a week in place of my own set which should be good enough.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Re: Orion 32" LCD
                        yes thats what i do with repaired items too be fair at least 1 weeks good test bymyself using all inputs etc saves any comebacks. I need to find some electronics again to try to fix etc maytry my local carboots in the new year as the cheap/free items on gumtree/facebook etc go so fast as a lot of people enjoy this hobby i guess.
                        • mikay786
                          • Aug 2014
                          • 765
                          Re: Orion 32" LCD
                          Most carboots close for winter, me an my brother in law were like junkies trying to find a fix when our local one closed last month!! There's a few other smaller ones but not worth the hassle.
                            ACER Predator Orion 5000 PO5-610 Predator Orion 5000 i7-9700K Specification for Upgrade or Repair
                            This specification for the ACER Predator Orion 5000 PO5-610 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 5000 PO5-610 boardview and Predator Orion 5000 PO5-610 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 03:28 PM
                            ACER Predator Orion 9000 Predator Orion 9000 i9-7900X Specification for Upgrade or Repair
                            This specification for the ACER Predator Orion 9000 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 9000 boardview and Predator Orion 9000 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            ACER Predator Orion 5000-610 Predator Orion 5000 i5-8400 Specification for Upgrade or Repair
                            This specification for the ACER Predator Orion 5000-610 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 5000-610 boardview and Predator Orion 5000-610 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            ACER Predator Orion 5000 PO5-610 Predator Orion 5000 i7-8700 Specification for Upgrade or Repair
