48 pin Chip, hot air station soldering, what am I doing wrong?
  • topfli8979
    • Oct 2012
    • 311
    Hoping someone can give me some advice, i ve been using a hot air station for a few years now, no issues soldering ic's,mosfets,transistors. Im going to be soldering a surface mount 48 pin chip to a main board for a repair. Ive been practicing on faulty boards and cant seem to get the solder to flow to each individual pin without clumping the pins together. Im using low temp solder paste, rosin solder flux, and about 400 degrees F. Each time I attempt this most of the legs get soldered individualy but there is always a few that clump or get a puddle effect, and I have to use the copper to separate them.. The videos on youtube make it look effortless with the required tools. What am I doing wrong?
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: 48 pin Chip, hot air station soldering, what am I doing wrong?
    i flood the chip with solder and flux and use hot air to remove, then use iron to solder in place, run solder with the iron down the sides of the chip useing flux, and then use 5mm braid to remove the non wanted solder from between the pins/legs, and i use a USB microscope to check
    • zomi
      • Nov 2011
      • 509
      To resolder
      Plenty of flux
      brigde 2 pins on each side.
      and then drag solder
      takes less than a min.
      • zomi
        • Nov 2011
        • 509
        Look here https://www.youtube.com/watch?v=wUyetZ5RtPs
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Azurain
          Elitebook 840 G5 Bios Chip Soldering Question
          by Azurain
          I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
          Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
          04-14-2023, 06:58 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • majster-pl
          Can a BIOS chip survive hot-air soldering but still lose functionality?
          by majster-pl
          I’ve run into an issue after working with a laptop BIOS chip and wanted to get some advice.
          I desoldered the BIOS chip using hot air and then read its contents with a CH341 programmer (only a read, no write or erase was done). The .bin file was not modified at all. After soldering the chip back, the laptop now no longer powers on.
          For clarity:
          No surrounding components were touched during the process.
          All pads were checked with test points and were confirmed OK.
          My question is:...
          09-08-2025, 04:21 AM
