Samsung PN50b550T2FXZA Y Sus BN96-09744A
  • R1racer
    • Nov 2015
    • 66
    Please help me trouble shooting this BN96-09744A , BOARD NUMBERS: LJ41-06153A, LJ92-01611A, 611A on sticker . I have sound after replacing the main board with supposedly brand new boar ordered directly from Samsung parts .. Vscan show the correct voltage .That's all i know how to test ..
    Thank you
  • jose6326
    • May 2013
    • 707
    Re: Samsung PN50b550T2FXZA Y Sus BN96-09744A
    you need to post clear pictures of the board layout of each individual board
    • R1racer
      • Nov 2015
      • 66
      New Main
      Logic
      SMPS
      X sus
      Y sus
      Buffer
      • Hamie
        • Apr 2014
        • 1383
        Short out pins 3 and 4 of the little black square located here:
        Disconnect the LVDS cable (the one that connects the control Board to the main board.
        Power on the tv.
        Do you get test patterns?
        • R1racer
          • Nov 2015
          • 66
          Power on the tv.
          I will check when i get home .Just curious What will the result proof
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Control board, in the centre of the Tv has lots of white ribbon cables coming out of it going to the panel and sustain boards.
            • R1racer
              • Nov 2015
              • 66
              I disconnected the Ribbon cable that connect the Main to logic
              Shorted Pin 3 and 4 on the Logic board
              Powered Set on and still received Black screen no test pattern ..What that mean
              • Hamie
                • Apr 2014
                • 1383
                It means that there's a good chance that the mainboard is working.
                If you got test patterns then your new mainboard would be faulty.
                In a dark room, Does the panel glow?
                • Hamie
                  • Apr 2014
                  • 1383
                  Is there a LED on the control board?
                  If so Does it blink every second or every 6 seconds?
                  • R1racer
                    • Nov 2015
                    • 66
                    The Panel Does not glow .. Total Black out to say
                    • R1racer
                      • Nov 2015
                      • 66
                      Yes there is a green LED and blinks every second
                      • R1racer
                        • Nov 2015
                        • 66
                        Was i suppose to connect the main board back after jumping pin 3 and 4 .
                        https://www.badcaps.net/forum/showthread.php?t=26790
                        Mentioning that on post #2 ...
                        • R1racer
                          • Nov 2015
                          • 66
                          Any one have other test suggestion to determine which board / component the cause of my problem .
                          • Hamie
                            • Apr 2014
                            • 1383
                            what voltage do you have for
                            VSCAN
                            VSCH
                            (located y-sus)
                            VE
                            {located on x-main)
                            • R1racer
                              • Nov 2015
                              • 66
                              I will tackle it when I get back in town and post the reading
                              It's good to take a break
                              • R1racer
                                • Nov 2015
                                • 66
                                VSCAN
                                VSCH
                                (located y-sus)
                                VE
                                {located on x-main)
                                Here is the result With the Set On
                                Vscan =-199 to -201 V
                                VSCH = ???? Could not find it
                                VE= 84 V
                                Also i have a q on previous test i performed DO i need to keep the main disconnected when i power the set during shorting pin 3&4 on the logic
                                • R1racer
                                  • Nov 2015
                                  • 66
                                  Any One ....!
                                  • R1racer
                                    • Nov 2015
                                    • 66
                                    Originally posted by R1racer
                                    Any One ....!
                                    bump
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      I repaired a Samsung PS50B430 TV that internally looks almost identical to this.
                                      Same symptoms, good vs va vsc and ve.
                                      Luckily though I had a spare control board from a PS42B430 lying about.
                                      Changing the control board fixed the problem.
                                      Basically you will need a scope to troubleshoot this further,
                                      or take a chance and buy a control board.
                                      • R1racer
                                        • Nov 2015
                                        • 66
                                        So what you saying is there a good chance that My Logic board is gone even with the Green LED flashing .?
                                        I am trying to understand is the VSCAN voltage is the only way to tell if the Y main is bad ?
                                        I also have access to scope but what should i do or test , Simply not sure what to look for
                                        I found this video as well and done all the steps except at Minute 3:26 where i was suppose to get test pic i did not see any thing displayed on the screen at all ,
                                        https://www.youtube.com/watch?v=JjrwTZC5nVg
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
