Samsung PN50b550T2FXZA Y Sus BN96-09744A
  • R1racer
    • Nov 2015
    • 66
    Please help me trouble shooting this BN96-09744A , BOARD NUMBERS: LJ41-06153A, LJ92-01611A, 611A on sticker . I have sound after replacing the main board with supposedly brand new boar ordered directly from Samsung parts .. Vscan show the correct voltage .That's all i know how to test ..
    Thank you
  • jose6326
    • May 2013
    • 707
    Re: Samsung PN50b550T2FXZA Y Sus BN96-09744A
    you need to post clear pictures of the board layout of each individual board
    • R1racer
      • Nov 2015
      • 66
      New Main
      Logic
      SMPS
      X sus
      Y sus
      Buffer
      • Hamie
        • Apr 2014
        • 1383
        Short out pins 3 and 4 of the little black square located here:
        Disconnect the LVDS cable (the one that connects the control Board to the main board.
        Power on the tv.
        Do you get test patterns?
        • R1racer
          • Nov 2015
          • 66
          Power on the tv.
          I will check when i get home .Just curious What will the result proof
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Control board, in the centre of the Tv has lots of white ribbon cables coming out of it going to the panel and sustain boards.
            • R1racer
              • Nov 2015
              • 66
              I disconnected the Ribbon cable that connect the Main to logic
              Shorted Pin 3 and 4 on the Logic board
              Powered Set on and still received Black screen no test pattern ..What that mean
              • Hamie
                • Apr 2014
                • 1383
                It means that there's a good chance that the mainboard is working.
                If you got test patterns then your new mainboard would be faulty.
                In a dark room, Does the panel glow?
                • Hamie
                  • Apr 2014
                  • 1383
                  Is there a LED on the control board?
                  If so Does it blink every second or every 6 seconds?
                  • R1racer
                    • Nov 2015
                    • 66
                    The Panel Does not glow .. Total Black out to say
                    • R1racer
                      • Nov 2015
                      • 66
                      Yes there is a green LED and blinks every second
                      • R1racer
                        • Nov 2015
                        • 66
                        Was i suppose to connect the main board back after jumping pin 3 and 4 .
                        https://www.badcaps.net/forum/showthread.php?t=26790
                        Mentioning that on post #2 ...
                        • R1racer
                          • Nov 2015
                          • 66
                          Any one have other test suggestion to determine which board / component the cause of my problem .
                          • Hamie
                            • Apr 2014
                            • 1383
                            what voltage do you have for
                            VSCAN
                            VSCH
                            (located y-sus)
                            VE
                            {located on x-main)
                            • R1racer
                              • Nov 2015
                              • 66
                              I will tackle it when I get back in town and post the reading
                              It's good to take a break
                              • R1racer
                                • Nov 2015
                                • 66
                                VSCAN
                                VSCH
                                (located y-sus)
                                VE
                                {located on x-main)
                                Here is the result With the Set On
                                Vscan =-199 to -201 V
                                VSCH = ???? Could not find it
                                VE= 84 V
                                Also i have a q on previous test i performed DO i need to keep the main disconnected when i power the set during shorting pin 3&4 on the logic
                                • R1racer
                                  • Nov 2015
                                  • 66
                                  Any One ....!
                                  • R1racer
                                    • Nov 2015
                                    • 66
                                    Originally posted by R1racer
                                    Any One ....!
                                    bump
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      I repaired a Samsung PS50B430 TV that internally looks almost identical to this.
                                      Same symptoms, good vs va vsc and ve.
                                      Luckily though I had a spare control board from a PS42B430 lying about.
                                      Changing the control board fixed the problem.
                                      Basically you will need a scope to troubleshoot this further,
                                      or take a chance and buy a control board.
                                      • R1racer
                                        • Nov 2015
                                        • 66
                                        So what you saying is there a good chance that My Logic board is gone even with the Green LED flashing .?
                                        I am trying to understand is the VSCAN voltage is the only way to tell if the Y main is bad ?
                                        I also have access to scope but what should i do or test , Simply not sure what to look for
                                        I found this video as well and done all the steps except at Minute 3:26 where i was suppose to get test pic i did not see any thing displayed on the screen at all ,
                                        https://www.youtube.com/watch?v=JjrwTZC5nVg
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
