Panasonic TX-L47ETW5 Led blinks 10 times
  • thoma
    • Sep 2012
    • 268
    Hallo to all of this very good forum!
    A friend of mine has a Panasonic TX-L47ETW5 LED Blinks 10 times LA35 Chassis
    Question who knows this mistake is it how often at Panasonic
    the A Board or what else?
    regards to all thoma!
  • jose6326
    • May 2013
    • 707
    Re: Panasonic TX-L47ETW5 Led blinks 10 times
    you need to post clear pictures of the board layout and individual pics of each board
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
      11-20-2024, 08:52 PM
    • fourroses73
      Panasonic Plasma TX-P46VT20 blinks 10 Times
      by fourroses73
      Hi all folks.
      My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
      Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
      What i have measured:
      Vsus and Vda are ok
      Pin1 of connector P7 : 5V ok
      Pin1 and 9 of connector P6: 16V in place of 15V but...
      12-03-2020, 05:28 PM
    • brithepi2k
      Samsung UE75TU7020k No picture, Standby blinks 2 times
      by brithepi2k
      My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
      04-23-2025, 10:05 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • Samunggg
      Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
      by Samunggg
      I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
      I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
      09-06-2023, 06:39 PM
