This that utilizes the STR-F6266 main switching regulator with most complicated circuits added. What set this apart is that is more common issue especially with guide plus module installed. The ones based on same chassis without this (just row of holes where socket is for guide plus module have much LESS problems.
Either in standby or run uses 2 feedbacks for regulation, one for 13V standby feedback or 135V run mode (using a SE135 IC). Well, Here the problem that is vexing me for years:
The 13V output 1,000uF 25V or 35V capacitor kept dying, average time is about 1-3 years between cap replacements) always swells it's top or sometimes blew it's top. The diode runs hot and that aftermentioned cap runs rather warm, in fact much worse when in standby. Other 3 outputs are cool as they should be, 135V for B+, 62V for tuner, and isolated audio supply.
WHY?
There are another chassis that uses same design except power supply uses different STR IC (fat retangular with off center mounting hole with more pins) for power supply did NOT have this cap busting issues.
Cheers, Wizard
WHY?
Cheers, Wizard
