Bn44-00514a psu no stby
    Re: Bn44-00514a psu no stby
    Originally posted by krygods
    So is this RM806 burned up just like the other resistor we put a 43 Ohm in place of?
    Yes you can, and then take the DCV reading between the two legs of the resistors so we can see how much current is flowing through them.
    • krygods
      • Dec 2014
      • 257
      I replaced RM806 and RM817 with 46 Ohm resistor and now RM882 is burning up and smoking when I plug in the TV
      • krygods
        • Dec 2014
        • 257
        Alright RM817 wasn't a 30 Ohm so i replaced that with the correct value. I replaced RM882 with a 46 Ohm and now nothing is smoking.
        Across RM806 the DCV fluctuates from 0V to as high as 1.2V on and off over and over.
        • krygods
          • Dec 2014
          • 257
          Just checked again now across RM806 I have 9.1VDC
          Still no DCV across the GATE and SOURCE of QM801
            The Voltage between 'A' and 'GND' is 26V is fed by DM81, please check the Diode. 26V feeding the two 30 Ohms (RM882, 806) Voltage divider resistors, that is lots of current (0.43A). I wonder if they are really 30 Ohms resistors. It is either the Voltage is too high or the resistors are not the correct value.
            'Just checked again now across RM806 I have 9.1VDC' that is almost 200mA! alomost 2W, RM806 is 46 Ohms, something is not right.
            • krygods
              • Dec 2014
              • 257
              is the Diode you are referring to DM831?? I don't see a DM81
              • krygods
                • Dec 2014
                • 257
                I have two other variations of this power board that are for 64" plasma but are the same.
                I tested RM882 and RM806 on those other boards and they measure around 170 kOhm but are marked '300'
                  That made no sense either.
                  • krygods
                    • Dec 2014
                    • 257
                    I have two boards P/N bn44-00515a they are the same just different size panel.
                    Reason i mentioned is that i am able to test resistors from those other boards if i need to in order to determine what the values of the resistors are supposed to be.
                    So I tested those resistors that I assumed to be 30 Ohm with 300 marking and they measured at around 170kOhm
                      That is I am not so sure if those resistors on the other board are also bad. We need working board or diagram to figure what is going on.
                      • krygods
                        • Dec 2014
                        • 257
                        Ok, I'll come back to this thread when I find a working board that we can compare to.
                        Thanks for the help thus far, I've learned quite a bit from this troubleshooting.
                        • f67bird
                          Technician
                          • Apr 2007
                          • 57
                          What you are looking at is most likely 30D
                          This is probably the EIA-96 marking system for 1% smd resistors.
                          EIA-96 code examples:
                          01Y = 100 x 0.01 = 1Ω
                          68X = 499 x 0.1 = 49.9Ω
                          76X = 604 x 0.1 = 60.4Ω
                          01A = 100 x 1 = 100Ω
                          29B = 196 x 10 = 1.96kΩ
                          01C = 100 x 100 = 10kΩ
                          more EIA-96 SMD examples...
                          01= 100 25= 178 49= 316 73= 562
                          02= 102 26= 182 50= 324 74= 576
                          03= 105 27= 187 51= 332 75= 590
                          04= 107 28= 191 52= 340 76= 604
                          05= 110 29= 196 53= 348 77= 619
                          06= 113 30= 200 54= 357 78= 634
                          07= 115 31= 205 55= 365 79= 649
                          08= 118 32= 210 56= 374 80= 665
                          09= 121 33= 215 57= 383 81= 681
                          10= 124 34= 221 58= 392 82= 698
                          11= 127 35= 226 59= 402 83= 715
                          12= 130 36= 232 60= 412 84= 732
                          13= 133 37= 237 61= 422 85= 750
                          14= 137 38= 243 62= 432 86= 768
                          15= 140 39= 249 63= 442 87= 787
                          16= 143 40= 255 64= 453 88= 806
                          17= 147 41= 261 65= 464 89= 825
                          18= 150 42= 267 66= 475 90= 845
                          19= 154 43= 274 67= 487 91= 866
                          20= 158 44= 280 68= 499 92= 887
                          21= 162 45= 287 69= 511 93= 909
                          22= 165 46= 294 70= 523 94= 931
                          23= 169 47= 301 71= 536 95= 953
                          24= 174 48= 309 72= 549 96= 976
                          Multiplier:
                          Z 0.001
                          Y or R 0.01
                          X or S 0.1
                          A 1
                          B or H 10
                          C 100
                          D 1000
                          E 10000
                          F 100000
                          So, 30D = 200k ohms
                          Learner
                            "I tested RM882 and RM806 on those other boards and they measure around 170 kOhm but are marked '300'" So may be it is 30'D', not '300'.
                            • pokepoke0610
                              • May 2014
                              • 28
                              I may or may not have a similar situation and have been reading this thread. I had originally made a post
                              called Samsung S64FH Sound but no picture. I had found that QS802 and QS804 were shorted. I bought the
                              replacement kit (which included those transistors) from ShopJimmy.com and have replaced those 2 MOSFETs.
                              I powered up my board (BN44-00516A) via a dim bulb fixture using a 100W light bulb. The light bulb did not
                              turn on which was a positive development. I have made the following measurements following the conversation
                              between budm and kyrgods
                              DC voltage across CP801, CP802, CP803 each measures 170V
                              DC voltage from "A" to GND: 25.5V
                              DC voltage from "B" to GND: 12.65V
                              DC voltage from "C" to GND: 12.65V
                              Resistance from "C" to GND: 130k and increasing
                              Gate to Source voltage on QM880: 7.4V
                              Gate to source voltage on QM801: 0V
                              Source voltage of QM801 to GND: 0V
                              I believe PS_ON measures 4.3V to GND (I made this measurement on the connector jumper labeled PS_ON)
                              I am trying to make sure that the power supply board is working properly (or as much as can be figured out) before
                              I reinstall it in the TV.
                              Any suggestions would be appreciated. Thank you.
                              • chth96
                                How Can I test PWM DM0365R?
                                by chth96
                                Hello
                                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                06-18-2025, 04:14 PM
                              • howardc64
                                Samsung UN65NU6950 edge lit TV LED bar after 10k usage hours
                                by howardc64
                                Edge lit LED TV has 1/4 section backlight out. Replaced the LED bars and sharing the findings on the original 10k hour LED bar.
                                These are 6V LEDS (reads ~5.4+ on my LED tester) New bars read about 147V per 1/2 of each bar. Clearly original LED bar has some problems
                                • One section is 153v with a dead LED so clearly built up resistance
                                • One section flickers but magically fixed itself after driving individual LEDs. All done with an LED tester so don't know if would work driven by PSU backlight circuit and how long it would last
                                • Connector pin to test pad resistance is nearly 0 ohms.
                                07-07-2025, 12:18 PM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • khelane
                                test active pfc power with lamp test
                                by khelane
                                Hello
                                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                Is there a way...
                                06-03-2025, 01:00 AM
                              • irepair559
                                Ps4 1215a hdmi diode readings good everything good but no pic??
                                by irepair559
                                PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                                01-05-2023, 12:32 AM
