Hi all, a very quick question. Can anyone tell me if buffer ic 3289F can be substituted by 3293F? Thank you!!
Buffer Ic Substitution
Re: Buffer Ic Substitution
Yes it can, guessing that this is a samsung set ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
No worries and yes most of the 3xxxf ics are interchangeable with no visible affects. Also you might need to repair the Ysus have you done so ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
No worries common issue is Ymain kills the buffer, are you replacing the Ic yourself ?
I have replaced a scan Ic before its not easy tbh as long as you use a good method.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Here is what I suggest:
Clean off all pins with solder wick and heatsink pad before doing anything then wash with Ipa
Apply solder to the heatsink pad under the Ic
Apply flux to the solder pad
Place Ic on top of solder pad
Heat area until molten, the Ic should fall into place as the solder from the pad will take to the ic, then lower heat slowly until off, and make sure that Ic is positioned properly
Apply flux to all pins around Ic
Apply solder on all pins don't drag it out !
Apply more flux to pins
Use flux based solder wick and wick up the large amount of solder around Ic, until you can see that pins are connect to the pcb but not shorted. You will need a lot of flux for this !
Clean with Ipa afterwardsPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Its hard to preform and you will need decent Smd skills, you can not hot air or heat plate the Ic into place you need to solder it with an iron.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
