Buffer Ic Substitution
  • simplytrini
    • Jul 2011
    • 73
    Hi all, a very quick question. Can anyone tell me if buffer ic 3289F can be substituted by 3293F? Thank you!!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Buffer Ic Substitution
    Yes it can, guessing that this is a samsung set ?
    • simplytrini
      • Jul 2011
      • 73
      Thank you ReeceyBurger123. Yes it is a samsung. Can they sub 3407f as well? Do you know? Thanks
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        No worries and yes most of the 3xxxf ics are interchangeable with no visible affects. Also you might need to repair the Ysus have you done so ?
        • simplytrini
          • Jul 2011
          • 73
          Yes Ysus needed repair as well. Thanks again!!!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries common issue is Ymain kills the buffer, are you replacing the Ic yourself ?
            I have replaced a scan Ic before its not easy tbh as long as you use a good method.
            • simplytrini
              • Jul 2011
              • 73
              Yes I am going to replace myself. I have a reflow station that i will use. Do you suggest anything specific from you experience?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Here is what I suggest:
                Clean off all pins with solder wick and heatsink pad before doing anything then wash with Ipa
                Apply solder to the heatsink pad under the Ic
                Apply flux to the solder pad
                Place Ic on top of solder pad
                Heat area until molten, the Ic should fall into place as the solder from the pad will take to the ic, then lower heat slowly until off, and make sure that Ic is positioned properly
                Apply flux to all pins around Ic
                Apply solder on all pins don't drag it out !
                Apply more flux to pins
                Use flux based solder wick and wick up the large amount of solder around Ic, until you can see that pins are connect to the pcb but not shorted. You will need a lot of flux for this !
                Clean with Ipa afterwards
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Its hard to preform and you will need decent Smd skills, you can not hot air or heat plate the Ic into place you need to solder it with an iron.
                  • simplytrini
                    • Jul 2011
                    • 73
                    ok. thanks again for all your help. I will post backonce I am done.
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Yanleb
                      Schematic or datasheet for Plasma TV buffer chip
                      by Yanleb
                      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                      05-18-2022, 01:36 PM
                    • legg
                      LG 42PC3 buffer output doesn't follow YSUS
                      by legg
                      LG42PC3D -UD originally with green lamp but no display or audio.
                      Owner says was working, then went 'pop'.
                      All 5V caps bulging. replaced.
                      All PSU output voltages within spec but -Vy is low on YSUS.
                      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                      eventually shorts DG. Replaced all 3 - -Vy now OK.
                      Y scan buffer test point does not follow YSUS output below -50V
                      Note: This unit seems to expect YSUS output to park at -Vy in between
                      drive signal pattern periods. A replacement drive signal board confirms this....
                      11-18-2021, 11:49 AM
                    • macmino
                      Buffer data does not match SPI chip!
                      by macmino
                      Hi all, after several attempt, I finally got a working CH341 Pro working USB device. Now I'm able to read dump the BIOS
                      When I verify the image (800G6_EC_RCunlocked.BIN found on this forum) I receive "Buffer data does not match SPI chip!". I tried different programmer but the message is the same. Anyway, I removed the password but I see at the boot the HP Message:
                      "HP Endpoint Security Controller Problem"
                      When I hit OK, the boot continues and I'm able to use the computer. Did. the SPI chip not match error caused the error?
                      09-08-2024, 09:52 AM
                    • shiz1
                      LG 50PT350 bad lower y buffer
                      by shiz1
                      Recently received an older lg plasma for free to fix.
                      Symptoms - no picture but i have sound. I hear the click of the relay, and the hum from the ysus.
                      What i've tried - i remove the ysus buffers one by one, when i removed the lower buffer i get picture on the top half of the screen. Removing the top buffer and leaving the bottom still gives me a black screen.
                      i tested the va/vs at the psu and they're within spec as outlined by the sticker.
                      I tested the lower buffer checking continuity between the white connector - see attached pics - on the...
                      01-13-2019, 04:02 PM
