Samsung PN51D7000FF cycling off and on
  • slcasner
    • Aug 2018
    Re: Samsung PN51D7000FF cycling off and on
    I'm examining a PN51D7000FF for a friend. It cycles every 15 seconds, which is faster than the durations mentioned in earlier posts here. The red LED blinks 5 times and a green LED on the main logic board also blinks. The Samsung logo shows on the screen and then then a rectangle in the upper left corner indicates that the HDMI1 input is selected. After a few seconds the power cycles off.
    My meter shows correct voltages for 5V, 15V, Vs=207V, Va=58V, Ve=80V and Vsc=-187V. I don't see any obvious signs of overheating or bulging caps.
    The friend has already procured a 4K OLED to replace this TV; I'm just checking to see if it can be saved from the e-waste heap. Based on the posts here, it sounds like the main logic board may have failed. The $120 replacement price is not warranted in this instance. Any other suggestions?
      09-07-2024, 05:50 AM
    • nosaj
      Samsung QN82Q70RA powers on then powers off
      by nosaj
      I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
      So I thought I'd just quit messing around and come to the best site...
      11-07-2025, 04:58 PM
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
      09-06-2024, 11:40 PM
