Ecran plasma Philips 32PFL5405H12
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Marque : PHILIPS
    Model : 32PFL5405H12
    philips: S Q552.1E LA
    Hello everyone.
    I have a plasma screen Philips Model: 32PFL5405H12
    screen displays horizontal lines next few normal left and right image.
    If one of you has already encountered this problem, I would be happy to receive his diagnosis.
    Avance.ci thank you to attach a default picture.
  • celiabrown
    Issue with Plasma Philips 37inch chassis FTL2.1
    by celiabrown
    Hello guys,
    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
    Can someone has any symptom like this ?
    Thanks​
    05-09-2024, 10:56 PM
    Fujitsu LIFEBOOK Ecran 15.6'' FHD Core i5-1035G1 | Win1 Notebook A Specification for Upgrade or Repair
    This specification for the Fujitsu LIFEBOOK Ecran 15.6'' FHD Core i5-1035G1 | Win1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ecran 15.6'' FHD Core i5-1035G1 | Win1 boardview and Ecran 15.6'' FHD Core i5-1035G1 | Win1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-06-2024, 08:40 PM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • double_DD
    Philips curling iron - is this a common AC cable?
    by double_DD
    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
    08-18-2025, 10:04 AM
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
