Toshiba 42HP66 dim, washed out patchy picture
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Toshiba 42HP66 dim, washed out patchy picture
    For some reason I'm just not satisfied, the speckles are driving me crazy! Can anyone tell me if replacing the control board might eliminate them or would the replaced board have to be flashed as well?
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • mmartell
      • Oct 2013
      • 3189
      If the maldischarge is even across the screen get your control board reprogrammed - these boards are reportedly married to the panel such that the board compensates as the panel ages.
      If the maldischarge is uneven forget it. The panel likely aged that way due to manufacturing defect common in these.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        What Colour is the mal-discharge....?
        Usual is red and will be cured by cont-board firmware.
        TELEFIX
        • WHaThEFLuX
          • Feb 2015
          • 277
          Not sure what you mean by "even", but it always shows up in the same places(evenly spaced apart in the middle of the screen). As for the color, with the Y board voltages within spec it's only red, however when I lower the VSC and -VY by ~5V-10V each the red disappears and is replaced by blue and green, which makes the set more watchable, but when you know it's there you just can't ignore it. I even notice it slightly on my other repaired panasonic plasma which functions perfectly.
          I can never look at a plamsa panel the same way again!
          -retiredcaps
          • WHaThEFLuX
            • Feb 2015
            • 277
            So it seems that I need to have the CTRL board firmware re-flashed and capkid is the man for the job.
            He hasn't been online in a few weeks, anyone know of another way to get in touch with him?
            -retiredcaps
            • WHaThEFLuX
              • Feb 2015
              • 277
              bump, anyone have a jig to flash LG plasma CTRL boards?
              -retiredcaps
                09-06-2024, 05:27 AM
              • mecha1166
                Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                by mecha1166
                I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                07-03-2024, 05:03 PM
                09-06-2024, 05:59 AM
