39L22U Toshiba LED TV
  • Gonnafix
    • Sep 2015
    • 37
    All of a sudden our TV just shut off last night as we were watching the last episode of Narcos.. I had been using an TERK HDMI switcher on the unit w power supply. Will not power up, no lights..nada. Can't find any resources on this model whatsoever. Does anyone have a schematic for this unit? I'm not getting the 12v on the indicated port on PS.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: 39L22U Toshiba LED TV
    Does the Power light come on at the front? are you getting StdBy 5Vdc? (It may be 3.6Vdc)
    • CapLeaker
      Leaking Member
      • 8158
      Pictures of the PSU?
      • Gonnafix
        • Sep 2015
        • 37
        No power light.
        I'm not seeing a mark for StdBy.
        Just these:
        BLON
        DIM
        ACD
        PWON
        5vcc
        12Vcc
        GND
        12Va
        GND
        Thank you!
        • Gonnafix
          • Sep 2015
          • 37
          Power supply is PK101W0000I
          • CapLeaker
            Leaking Member
            • 8158
            check if 5vcc is there
            • Gonnafix
              • Sep 2015
              • 37
              5vcc would be 5v DC correct? No voltage..
              • Gonnafix
                • Sep 2015
                • 37
                Just making sure here.. Do I check using the 5vcc and GND contacts on that connection point?
                • CapLeaker
                  Leaking Member
                  • 8158
                  yes
                  • Gonnafix
                    • Sep 2015
                    • 37
                    No voltage.
                    • CapLeaker
                      Leaking Member
                      • 8158
                      O.k. So now you have to be really carefully as you are going to be checking the primary side of the power supply. Measure if you have any DC power on the 2 long brown filter caps. Don't slip. Positive and Negative on each capacitor. You should see 170V DC or so.
                      Check that 4A fuse (with the power off) and your meter set to resistance (Ohms)
                      We also are going to need a picture of the backside of the PSU.
                      • Gonnafix
                        • Sep 2015
                        • 37
                        No voltage at the 12Vcc or 12Va either..
                        • CapLeaker
                          Leaking Member
                          • 8158
                          we have to figure out why there isn't any 5v there. Without it nothing is going to work.
                          • Gonnafix
                            • Sep 2015
                            • 37
                            Reading on both caps is .3
                            • Gonnafix
                              • Sep 2015
                              • 37
                              Fuse is blown.. this seems to good to be true.
                              • CapLeaker
                                Leaking Member
                                • 8158
                                unplug the psu and check that white fuse with your meter set to resistance, measure across the fuse.
                                • CapLeaker
                                  Leaking Member
                                  • 8158
                                  O.k. if the fuse is blown, to 99.% there is something else bad too. So you would have to check all diodes, and Mosfets for a short in the primary circuit. Also check the bridge rectifier for a short. PSU not connected to power anymore of course.
                                  • Gonnafix
                                    • Sep 2015
                                    • 37
                                    Will do. Going to go get some fuses and a 60watt soldering iron. I suspect it will have a few bad parts. I just don't want to buy a replacement PSU. What fun would that be?
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      60 watt?
                                      30 watt max i'd say
                                      • Gonnafix
                                        • Sep 2015
                                        • 37
                                        Originally posted by anotherdude
                                        60 watt?
                                        30 watt max i'd say
                                        I'll stick to the 30 then..
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
