Samsung le32a457/c1d new caps but t-com fuse issue
  • wilson_campbell
    • Feb 2015
    • 40
    • United Kingtom
    New to working with TV etc so if I make any mistakes in my terms that is why
    Had the usual problem with with samsung caps (red light flashing but no power). Sometimes would eventually come on and sometime quickly and sometime not at all.
    did following:
    Only 1 was cap on cold side of power board visually gone so replace it but issue remained.
    Replaced all the major caps plus resoldered some poor solders on npn transistor qb802. Then had no pic but sound + black light working.
    With power on and not in standby: Checked all connectors going into control board from power board, all voltages match on main ribbon connector. On smaller connector :
    blu = 5.21
    adtm = 3.43
    pwm = 4.9
    gnd = 0
    +bv = 5.39
    Identified T-com 3am smd fuse blown. Checked AMPs and seemed to spike. Pulled and checked npn transistor qb802 with multimeter and all OK. Resoldered. Spike seemed to be gone. Replaced fuse and tried again but fuse blow again.
    Would anyone have advice on where to proceed from here. All solder joints seem ok.
    I would be greatfull if someone could also confirm the following is normal: When measuring amps at the power board connector for (ps)or at the t-conn fuse the minute I touch them the tv resets itself as if going from standby to on again. I can only think that the multimeter when reading amps is pulling out enough power that the control unit is sent into sandby mode because of the drop in power.
    You help would be greatfully appreciated as my kids are driving me made as it is now 2 weeks since it broke
    Sorry no pics as everytime I try to upload pics it finishes the upload but does nothing. Will try again later.
    Last edited by wilson_campbell; 08-22-2015, 01:28 PM. Reason: Cannot get pics to upload
  • wilson_campbell
    • Feb 2015
    • 40
    • United Kingtom
    Re: Samsung le32a457/c1d new caps but t-com fuse issue
    Pics of power board and control board now attached
    • chrismurphy
      • May 2014
      • 251
      • australia
      replace T-con board (main board)
      • wilson_campbell
        • Feb 2015
        • 40
        • United Kingtom
        hi,
        The t-con was working before I replaced the caps in the power board. Would it just be a coincidence that the t-conn has now gone or is something in the powerboard causing/caused the issue.
        My be a moot point now as when I was checking the amps again on the t-con fus, I held the millimetre probe on it for longer and some of the resisters on the control board nearly caught fire and was smoking. Controller board now probably fried.
        • CapLeaker
          Leaking Member
          • 8146
          Yep. There is a dead short somewhere.
          • wilson_campbell
            • Feb 2015
            • 40
            • United Kingtom
            Thanks )
            Strange. The parts that overheated where on the separate control board (board seems to still working as sound still there). The parts I changed/resolder where on the different power supply board. The power supply is generating the correct volts at the pins from the power supply. Although I am not sure about the correct voltages for the smaller connector going from the power board to the control board (not stated on board).
            If I had caused a short circuit in the powerboard would the pins show correct voltage etc. + then cause a dead short on the control board.
            • sordids999
              • May 2013
              • 2152
              remove all the yellow glue on the power board it can become conductive over a period of time
              • wilson_campbell
                • Feb 2015
                • 40
                • United Kingtom
                Removed the glue around the NPN transister (will do rest later) and now the fuse is not blowing each time.
                Have picture now but just multicolour vertical lines and does not show tv/menu image at all. Would I be correct in saying this means the t-con is fried (did try receding the ribbon cables into the t-con).
                  09-07-2024, 05:50 AM
                • jesterace
                  Samsung UE46ES8000 Blown fuse but no other signs of short
                  by jesterace
                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                  09-11-2024, 03:14 PM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                • Manucsl
                  QE65Q800TATXXC Samsung TV Issue
                  by Manucsl
                  Hello.
                  My TV is a QE65Q800TATXXC Samsung TV.
                  Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                  Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                  Any ideas to check would be very appreciated 😊
                  After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                  02-19-2025, 07:47 AM
                • ScHAmPi
                  Samsung UE48JU7000 screen issue after backlight replacement
                  by ScHAmPi
                  Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                  I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                  07-15-2024, 05:41 AM
